I'm sure for most of you this will be an easy question.
Can someone please tell me what issues I may encounter if I try to swap an 83 motor into an 86 car. No turbo or anything fancy, just early motor into a late car. I know the fuse location and ecu are different but will a late wire harness and under the hood accessories mate up? I have a 86 944 with no motor, ecu or exhaust but has tranny and power steering. I can get a 83 parts car with motor, ecu and exhaust for next to nothing. Will this work? Thanks. |
Used & Abused
It all should go together. There's no ISV on the early cars so you'll have an extra unused connector from your late harness. You may not have a power steering pump on the donor as it was optional on the 83s.
Goood luck.
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
Is it true the early/late temp sensors differ?
Toofah King Bad
Different ECU and wiring?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Yes, they are different. The early car has a 1 wire temperature sender under the intake manifold as opposed to a 2 wire setup. That changed in 85.5 along with a few other things.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
The fuel line hookup might be different, you might need to transfer the fuel rail form the old engine like I had to
No powersteering.
| Tags |
| engine , motor , swap |
