-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   dumping the bov in to the intake (http://forums.pelicanparts.com/showthread.php?t=515873)
Paulyy 12-11-2009 03:17 AM
I’ve seen it on a few cars where people dump their bov waste in to the intake of the turbo. Does this make any difference? Quieter bov dump? Anything at all, increase in turbo spool?
Techno Duck 12-11-2009 06:23 AM
The 951 uses a recirculating bypass valve stock.
wild man 12-11-2009 08:56 AM
Yes, it does help keep the turbo spooled better between shifts. I would think that it would be as stock on a 952, as it is on a 951. It sounds like you are saying that yours isn't. There should be about a 1" (25mm) hole sticking straight up on the left side of the J-boot where the bypass valve, or BOV, if you like, dumps into it.
P.S. I think it would be "somewhat" quieter dumping into the intake, but it is still quite loud.
Paulyy 12-11-2009 06:42 PM
nah i dont have a stock set up. i bought and the airbox was replaced with pod filter and a tial bov.
yeah 951&952's are the same pretty much just the 952 is a rhd and a 951 is a lhd. just with the different country option codes.
wild man 12-12-2009 04:28 AM
I suppose it is only the interior of the 952 that is a "mirror image" of the 951. I can't imagine the engine being a mirror image, with a left bank of cylinders, instead of a right bank.
Anyways, I 'm not sure what a pod filter is, but I have aftermarket MAF conversion (autothority), and it still has a port in the pre-compressor intake pipe for the "BOV" valve to dump into.
