On Boost
dumping the bov in to the intake
I’ve seen it on a few cars where people dump their bov waste in to the intake of the turbo. Does this make any difference? Quieter bov dump? Anything at all, increase in turbo spool?
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head. |
That Guy
The 951 uses a recirculating bypass valve stock.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
All Spooled Up
Yes, it does help keep the turbo spooled better between shifts. I would think that it would be as stock on a 952, as it is on a 951. It sounds like you are saying that yours isn't. There should be about a 1" (25mm) hole sticking straight up on the left side of the J-boot where the bypass valve, or BOV, if you like, dumps into it.
P.S. I think it would be "somewhat" quieter dumping into the intake, but it is still quite loud.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) Last edited by wild man; 12-11-2009 at 08:59 AM.. Reason: added P.S. |
On Boost
nah i dont have a stock set up. i bought and the airbox was replaced with pod filter and a tial bov.
yeah 951&952's are the same pretty much just the 952 is a rhd and a 951 is a lhd. just with the different country option codes.
All Spooled Up
I suppose it is only the interior of the 952 that is a "mirror image" of the 951. I can't imagine the engine being a mirror image, with a left bank of cylinders, instead of a right bank.
Anyways, I 'm not sure what a pod filter is, but I have aftermarket MAF conversion (autothority), and it still has a port in the pre-compressor intake pipe for the "BOV" valve to dump into.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
