Tips for replacmenet breather hose from Air Oil Separator?
I'm looking for the breather hose that goes from tha AOS to the hardpipe under the intake manifold. On my 951 late version it is a simple 90 degree knee with a fixture for the one way breather valve. There is no part number for this hose in the parts catalog. It seems to come as a part of the hard pipe assembly.
Does anyone know what will work as a replacement for this hose?
I figure I could use a t-junction and a reduction coupling to fit the valve, but I would much prefer a proper purpose made hose.
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 02-10-2010, 11:34 AM
That Guy
Techno Duck's Avatar
The check valve is not 100% necessary and many just do away with it (it was also only on the later cars). It was said the function of the check valve was to prevent a little oil smoke from the exhaust at full boost and prevent high pressurization in the vent line (like if the line gets clogged with oil accumulation). I have not noticed a difference with or without it since i removed it. You can replace that hose with just a 3/4'' or 19mm silicone or rubber hose(make sure its oil rated...IE; not radiator hose).
Look up the 'venturi delete thread' on Rennlist in the 951 forum. There is a good thread that shows one way of plumbing everything if you wish to retain the check valve. Personally i think its more trouble than its worth.
This was my solution using a 19mm 90* elbow and some 19mm straight hose. I deleted all the hardpipes under the intake to simplify the routing (i had already deleted the CV, so i didnt need any of it). You can essentially do the same. This picture shows how i had this setup when i was still running the stock turbo and no catch can. I had one 90* elbow, some 19mm silicone hose and a 45* 19mm elbow to attach back to the stock j-boot. I also had a few 19mm couplers to connect everything. You can basically do the same and retain all those hardlines, you would just need a 19mm 90* elbow.
This is what the original hose looked like when i pulled it with about 100k miles.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-10-2010, 12:24 PM
Thanks TD.
I'm not planning to keep the car for long. Due to a medical condition I may not be able to drive for much longer. That's why I want to keep everything as stock as possible, including that little valve. I'm figuring the car will be easier to sell on that way. I would definitely go with your solution if I was planning on keeping her. surely some other car maker must be using a similar hose for some application?
Old 02-10-2010, 01:09 PM
