Strange vibration?
Just changed all the belts and waterpump and seals.... It developed a vibration starting at about 3500 and getting worse through the range.... My thought was balance shafts out of time... So I took it apart again and they right... Its all in time and the tensions are good. What else should I check? I noticed the pulleys for the AC and PS are both weighted.... Do I need to offset those weights?
Old 05-01-2010, 10:40 PM
It's most likely that you have installed one of the balance shaft pulleys in the wrong keyway.
Good luck, George Beuselinck
Old 05-02-2010, 07:17 AM
Just thinking out loud
mattdavis11's Avatar
Check the O and U.
91 FJ80
84 Ram Charger (now gone)
Old 05-02-2010, 07:22 AM
