clack clack clack from rear?
Sitting in the car, still, engine running, shifter in neutral, clutch pedal not depressed, there is a rhthymic clack clack clack from the rear. Sounds like it's coming from the vicinity of the transmission or the torque tube. Not real loud but noticeable.
Goes away when I depress the clutch pedal.
Is this normal transmission noise? Torque tube bearings? The car has 84K miles on it.
1987 944S
Old 04-19-2010, 07:17 AM
Toofah King Bad
Rasta Monsta's Avatar
Clack? Yikes. Easy first step, drain tranny oil and inspect for debris, then replace with Redline.
Oh, and before removinng the drain plug, make sure you can crack the filler plug.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-19-2010, 08:27 AM
In my experience on other vehicles, but not necessarily applies to a 944...if the clack goes away when you are in gear or push in the clutch, it could be the clutch cable is loose/out of adjustment. I know that's not at the rear but it may be rattling the shaft.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 04-19-2010, 10:04 AM
Interesting. It's not a loud or nasty sound, but ???
I'm not draining the oil and replacing with Redline - I just drained and refilled with Swepco last fall. Very little debris on the magnet at that time.
Also, the clutch is hydraulic, so no clutch cable.
1987 944S
Old 04-19-2010, 12:51 PM
Even if you're not going to replace the fluid, I'd still drain the oil to check for any metal shavings/chips. Do you hear any kind of noise when driving? Also, might check for a bracket that might be loose, allowing something to vibrate at the low rpm of idle.
'86 944 Turbo
You have to be a masochist to love something so frustrating.
Old 04-19-2010, 03:54 PM
commdiver's Avatar
Sounds like your torque tube bearings are going! 30 years of exhaust heat and sitting kills them! If you dont want to drain your transaxle your not going to want to change the torque tube bearings! Drop transaxle, drop exhaust, drop rear suspension, remove starter, remove torque tube!
Re-build torque tube and replace in reverse order!
14hours later!
'83 944 ROW zermatt silver/black, sunroof & A/C factory deleted, houndstooth sport seats, 7Q - 220 LSD short fifth, F & R 23.3 MM 951 M030 suspension, 16" fuch's, manual windows, club sport mirrors, Blk/Wht gauges, rear seats & all sound deadening removed, 968 rear wing, fiberglass hood & 937 F bumper
Old 04-19-2010, 08:47 PM
joeporsche1's Avatar
As far as bearings replacing there the worst to replace. Havent done
it though I readread a few tech articles how toos on the subject a
few yrs back.
Like a blueberry banana smoothie with oranges & apples daily with vanilla n coconut if you like.
Old 04-20-2010, 01:06 PM
Torque tube bearings!
There are four 6006z or 2z bearings in an iron frame with outer seal.
Easy to fix,but you must remove the tranny,all the exaust sistem,starter,sleave cylinder and the harder:disconect rear breake line and put down a little the entire rear axle(clarence for put out the torque tube)
With the torque tube out i sprayed inside with a soap emulsion to put out easy the bearing assembly.Change in the same time the pilot bearing,posibly do a clutch job and if you want an aluminium flywheel-sublime for this cars!(this engine must to rotate a big flywheel,two very heavy balance shaft and a heavy torque tube).This is good for a tractor deisel!!!
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 04-20-2010, 01:47 PM
