P944GUY's Avatar
ZDDPLUS additive
was wondering if anyone adds the ZDDPLUS oil additive to their oil....adds zinc and phosphorus back to the oil..and firstly, does the 944 have the flat tappet or roller...this additive is designed for flat tappets...
feedback...
Old 06-21-2010, 01:34 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
flat - direct cam to lifter contact
also curious where to get it..
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 06-21-2010, 02:13 PM
P944GUY's Avatar
looks like just online so far...ZDDPLUS
http://www.zddplus.com/index.htm
or
http://www.rsbarn.com/zdd_additive.html
or
http://www.lindseyracing.com/LR/Parts/ZDDPlus.html
Old 06-21-2010, 04:08 PM
Toofah King Bad
Rasta Monsta's Avatar
ZDDP is included with Red Line, Royal Purple, and Brad Penn oils. Other oils are reducing it for emissions purposes, and (at least anecdotally) can destroy your cam.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-21-2010, 04:18 PM
how would it destroy your cam? never heard that before
Old 06-21-2010, 04:32 PM
P944GUY's Avatar
OK..I'll bite....would you mind explaining why it would destroy the cam.....some people rave about the Brad Penn oil and use nothing else and use it because it has a small amount of the ZDDP in it....and it's not cheap at $10-11 a quart.......so at $10 a bottle for the ZDDPLUS--seems like a cheaper alternative......haven't used either so I don't know first hand....so the ZDDPlus claims to save your engine by reducing wear :
the ZDDP molecule quickly plates over the contact surface with an extremely thin glass-like film and provides a sacrificial coating. As soon as the engine conditions get back to normal, the film dissipates back into the oil solution. This action prevents the lifter and cam from making contact and greatly reduces the tendency of parts to scuff and gall under heavy-loaded boundary lubrication situations. ..it sounds good, and at one time I'm sure the oil used in my car prior to 1988 had it in it....
Old 06-21-2010, 04:39 PM
Toofah King Bad
Let me google that for you
Old 06-21-2010, 05:05 PM
P944GUY's Avatar
I see, so what they are saying is that the lack of ZDDP in our oils is destroying our engines..just ordered some from Lindsey racing..putting it in with my next oil change
Zddp Oil Issues
Old 06-21-2010, 05:32 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Lucas has a zinc or ZDDP product sold at Advance. I'm skeptical of any "pour it into your engine and make it run better" bottles. I'll just stick with Mobil 1 I think...
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 06-21-2010, 05:44 PM
your average wrencher...
man, i get brad penn for 52 a case with tax.....that's only 4.34 a qt....
on a jeep site I visit: http://www.jeepsunlimited.com/forums/showthread.php?t=428969&highlight=cam+lobe+wear
good pics for what can happen to hydraulic lifters
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 06-21-2010, 05:49 PM
i think you are reading your information wrong. older oils had higher levels of zddp which our cars need, the new gf certification has much lower amounts than what our cars are used to seeing, so without the zddp we have a chance of damaging the engine components not with.
1983 944 Guards Red (87' Implant Complete)
Old 06-21-2010, 06:53 PM
Toofah King Bad
+1
Old 06-21-2010, 07:10 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
I highly recommend, Don't do it..
Visit my page, I have some very important updated info on that ZDDP stuff.
It will clog up your oil filter screens and etc.
Upgrade to a better Synthetic lubricant instead.
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 06-22-2010, 09:30 PM
Schumi's Avatar
Find some old-style Rotella T 20W50 if you can. You're in AZ, so it's warm there. They still made it with high levels of ZDDP for diesel trucks and whatnot up until reccently, and small auto parts stores may still carry the older jugs of it. It's cheap, plentiful, and from my experience works great in these engines.
M
Old 06-22-2010, 10:14 PM
choinga's Avatar
I use Brad Penn 20W-50 and love it. Even if it is a few bucks more per quart...why screw around with something so important like engine oil...especially in a 20+ year old engine? I can see cutting corners in a lot of places...but not here.
Old 06-22-2010, 11:40 PM
flash968's Avatar
it's amazing at how much discussion there is over oil, and how many things people assume, but turn out to be wrong
i recently found out, and it was investigated with the manufacturer who verified it, that an oil many people love, does not hold up beyond 260 degrees, which is very commonly hit on the track - it resulted in 3 engine failures on 3 different cars in one day, and they were the only cars to fail like that
i'm not going to mention the oil, because i don't want to get into the inevitable "i've never had a problem" presumptions that people tend to make, but the bottom line is that you need to look at the chemical makeup and the data, and not just your buddy's recommendation
as for ZDDP, there is plenty of data out there to support the need - i am not a fan of additives, and prefer to buy something with the correct compounds already in it
Old 06-23-2010, 07:39 AM
i guess its good mine doesn't see the track or much stop/go city driving then.......
1982 931 *project*
Old 06-23-2010, 09:21 AM
Back from Beyond
I'm with Schumi on this one.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-23-2010, 11:12 AM
It seems as if a can of worms is opened every time we talk about what engine oil is the best for our cars. Spend the time to read up on several brands of oil and the one you now use. You can then make an informed decision on what oil you should use. If you cheap out on the oil you should change it out more frequent as the additives will break down faster. No real savings there. The newer cars have longer periods of when they say to change the oil. Where you live, hot and dusty or humid all plays a part in oil changes. I only know what works best for me, and my cars have been on a steady diet of Brad Penn for years. I change the oil out every 6 - 7 months and I'm not a 45 mph Grandpa.
Cheers,
Larry
Old 06-23-2010, 02:35 PM
I think he meant to say "cat." High levels of ZDDP is 'supposed' to foul a cat sooner than normal. I found STP Oil Treatment (Red Bottle with higher ZDDP content) at Big Lots. They have a ton of it .
'86 944 N/A
Metallic graphite
Old 06-23-2010, 06:27 PM
