I passed! (but...)
So, I had the pleasure of doing one of our fun bi-annual smog tests here in the Golden State. I passed (original cat) but upon looking at the numbers it appears I've got something going wrong.
All of the test measurements produced numbers pretty far below the max and and below average...except for 1. On the hydrocarbon measurement at 15MPH I was exactly at the max and for the 25MPH I was close. I also noticed that my oxygen measurements for both of those were 0.0%. As much as I'd like to believe my engine is running perfectly efficient, consuming every oxygen molecule, I don't think that's right. I'm thinking either my oxygen sensor is done or my AFM needs to be "retracked." Anybody with a BTDT story here?
-Stephen 00 Boxster S 6MT 03 Subaru WRX w/EJ207 swap 16 Cayman GT4 21 Genesis G70 3.3T |
Proprietoristicly Refined
Leave it alone if you passed and just smile as you go by an emissions station----until next time.
This may not help but the owner now lives in CA: Failed CA smog... - Rennlist Discussion Forums 60K is usually max for a O2 sensor. Get the Bosch interchange that FRWilk posted. Follow his instructions-----crimp! No solder. Oxygen Sensor AFM HondaDusTR did a complete video and writeup. http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/493906-air-flow-meter-fix-refurb.html GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
I don't want to sound like I'm complaining about passing, but it just seems like something might not be running right. I've also noticed that my motor seems to produce the most torque between 5000 and 6000 -- which isn't right.
I've never retracked my AFM as I'm a little apprehensive, but with 133,000 miles on the original one, it probably needs it.
Location: In a dumpster behind Albertson's in Los Angeles County
scooby...if you ever have a problem with your smog again, I know a "great" smog guy.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Redline Racer
The FrWilk O2 part number worked ok, but a different part cross referenced by a Bosch guy on rennlist awhile ago seemed to work better for me and comes with a nice water resistant splice kit.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/514367-test-results-new-universal-o2-sensor.html
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Redline Racer
Well, smoothly is a relative term here. It does kind of rattle the car, but the power pulses are nice and even and does make useable power, but it's also had a fresh valve job, mild porting work (especially intake), and a chip. The 944MAX chip does wonders for the low end part of the torque curve, but still uses the o2 sensor for part throttle, so the correct sensor did seem to improve it. It will pull in 1st, 2nd, 3rd, 4th that low to avoid a downshift around town. The stock chip would never do that. The 944MAX will definitely climb much bigger grades in 5th than the stock chip could.
Under the car
FWIW, I had an FRWilk chip in there but it was causing high-throttle detonation, even with 91 octane. It did, however, produce amazing throttle tip-in response.
