-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Will 86 turbo struts/springs fit a 86 NA? (http://forums.pelicanparts.com/showthread.php?t=556884)
RedDragon 08-03-2010 11:52 PM
I'm refreshing a 86 NA 944 and have found a set of used front struts, springs, mounts (the lot).
1. Will they bolt straight into my NA or do I need the turbo hubs as well?
2.How can I tell if they are from a late (87+) or early offset car?
3. They look to be in good shape but just in case how much is it to get the konis serviced/rebuilt?
I already found a set of koni rears, 951 sway bars, and have ordered new bushings for everything. The fronts are the last on my suspension 'to do' list.
Cocacolakidd 08-04-2010 01:30 AM
The Turbo parts will fit a NA only if you change out the Spindles also. The Hubs are the same on '83 to 91 944's and Turbos. Different mounting on the Struts for Turbo's and Na's - Springs will work NA's and Turbo's, early and late. Different parts - spindles and Struts on late '87 and up.
If you do go with the upgrade Turbo spindles to fit the Turbo Struts on your '86 NA now the NA Calipers and Rotors will not fit. So you now have to upgrade the Calipers to the Turbo/Brembo Calipers and the larger Turbo Rotors (Nice upgrade).
To send off to an authorized shop and have the Struts rebuild/re-valved is almost as expensive as new ones. Go with the INSERT Replacement on the struts and rebuild them your self that way and save allot. The new insert replacement should be Part No. 8641-1038 Sport and they are externally adjustable...
See also this thread for the insert replacement ---> http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/337896-weekend-project-pics-koni-inserts.html
944 Ecology 08-04-2010 04:08 AM
The 86 turbo hubs are different from the 86 na hubs... one year part only.
RedDragon 08-04-2010 05:13 PM
Thanks guys. So the answer is no, the 951 strut/spring unit won't just bolt in.
hopps 08-04-2010 05:56 PM
Pretty much! I tried this myself, only to be severely disappointed haha!
DannoXYZ 08-05-2010 06:57 PM
You can use the front 951 springs on your NA though. And sway- bars if you can find them. They make a significant improvement to handling with minimal spending.
RedDragon 08-06-2010 06:35 AM
Thanks Danno. I just put a springs wanted ad up in the for sale section. I already have some late 951 sway bars. I just need some front springs and shocks now.
Cheers
VINMAN 08-06-2010 06:48 AM
I thought the turbo springs were a different diameter?? Smaller?
RedDragon 08-06-2010 05:46 PM
Is that true?
Cocacolakidd 08-06-2010 10:46 PM
Same size - tension/spring rate different
RedDragon 08-07-2010 12:54 AM
Thanks cocacolakid. I thought they would be the same size, just different rates.
