Porsche Crest Recommended coolant
I recently replaced the coolant in my '88 944 with distilled water and Prestone (no idea what was in there when I bought the car). If I were doing it over again I would have sourced some Porsche spec coolant. Any comments on issues/ problems using non-Porsche coolant?
Old 08-09-2010, 08:16 PM
I use PEAK Anti-Freeze and can't remember if it's on the bottle, as long as it says "Phosphate Free" you are good to go. I researched before using and was already using Peak in my other cars.
Cheers,
Larry
Old 08-09-2010, 09:34 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Stick with the "known, better" brands, Prestone, Peak etc. As for "phosphate free", that really is only a problem in countries like Europe, where there are many more minerals in the water (hard water) than in the US. Sure you can use "Porsche Specific" antifreeze, it's only $36.00 a gallon (and really only a requirement on the Boxster, 996 and later water cooled P-cars).
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 08-09-2010, 11:32 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Was going to recomended;
Plain old AIR... but not sure about the Sense of Humor level of the forum
Who Will Live... Will See
Old 08-10-2010, 02:25 AM
Toofah King Bad
Rasta Monsta's Avatar
I use Valvoline.com > Products > Zerex > Antifreeze Zerex > Zerex G-05® Antifreeze / Coolant.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-10-2010, 07:29 AM
NY944Turbo
minho78's Avatar
Cheers,
Larry
+1. Phosphate Free
Old 08-10-2010, 07:35 AM
+2 = as long as it says "Phosphate Free"
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 08-10-2010, 08:14 AM
Old 928 Guy
surfdog4's Avatar
What he said....Phosphates cause minerals to settle out of the water, even if there are phosphates in the antifreeze it wouldn't be a problem unless you were also using very hard (lots of minerals) tap water along with it...it's a scare tactic to get you to pay for "Genuine" antifreeze
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 08-10-2010, 09:25 AM
Toofah King Bad
There is info out there indicating that for cars like my 931 (alum head, cast iron block) phosphates can contribute to aluminum corrosion.
Old 08-10-2010, 09:32 AM
89-944NA's Avatar
JJ 911SC Aren't you just another "air head"? You got air cooled, we got balance, horsepower, and room for that long legged blonde with the HUGE bumpers and her twin sister. lol
Semper Fi
Old 08-10-2010, 10:01 AM
JJ 911SC's Avatar
Arrow Isee that...
... there is no bitterness between the cooling faction
Old 08-10-2010, 10:37 AM
ernie9944's Avatar
[QUOTE=wharlos;5498226]I recently replaced the coolant in my '88 944 with distilled water and Prestone.
I've use Prestone 50/50 for 26 yrs in my 944 NA now have the same in my 968 ,no problems with neither of them up to now. 911 SC ___ Long life to both.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 08-10-2010, 11:24 AM
ernie9944's Avatar
I did some research on the long legs & ON THE 944 turbo S they came as an option ,the 968 had them as standard equipment.
Old 08-10-2010, 11:36 AM
flash968's Avatar
porsche is VERY specific about using phosphate free coolant - failure to do so voids any warranty of the pump, radiator, etc
tap water contains minerals - these minerals are known to build up in the radiator and clog it, thereby reducing its efficiency
NEVER use tap water - ALWAYS use distilled water
Old 08-10-2010, 12:56 PM
89-944NA's Avatar
Distilled water also negates the need for phosphate free antifreeze, as there are no dissolved solids in distilled water. I have warrantied many water pumps in my dealings with Porsche 944's etc, and never had a warranty refused because I didn't use phosphate free antifreeze.
The only vehicles that Porsche is very strict on coolant is the newer water cooled head engines, 996, Boxster, Cayman etc, and they REQUIRE the use of Porsche Coolant.
As I said earlier, the phosphate free antifreeze is only required in countries with water that contain high levels of dissolved solids (hard water). Also, in discussions with a senior manager with PCNA and the Head Technician (30+ years) at my local Porsche dealership, both stated that phosphate free antifreeze is not required in the United States due to our better quality (softer) water than most countries, but the expense of changing the wording (to delete the reference to phosphate free antifreeze) in owners manuals for US cars was not deemed necessary.
Also, distilled verses tap water is NOT A REQUIREMENT, but a personal preference (but yes, I do use distilled water). My car never runs over the lower mark on the temp gauge unless I am stuck in the aforementioned LA traffic, where it may rise to the middle of the gauge.
Gentleman, what we are discussing here is more personal preference than hard fact, and we have strayed from the original posters question, "Any comments on issues/problems on using non-Porsche coolant?"....
In a nutshell, there are NO ISSUES with using "aftermarket" coolant in our pre-1997 water cooled cars, other than the actual cost of the coolant itself, "aftermarket" coolant about $12.00 per gallon, Porsche coolant $36.00 per gallon. Your preference and wallet will decide which you should use.
Semper Fi
Old 08-10-2010, 05:02 PM
your average wrencher...
lot of guys run the vw pink stuff
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 08-10-2010, 05:05 PM
flash968's Avatar
i understand what 88-944A is saying, and cannot disagree with the concept - my dad ran the west coast's largest antifreeze packaging plant for 20 years, so i know a lot more about coolant than i would like to (for example which brands are really other brands)
that being said, i called porsche north america when i first got my blue 968 - long story but the idiot who did the work on the car only used watter wetter and water, and i wanted coolant - not knowing what to use, and not wanting to void any warranties, i called them for the official recommendation - i was on hold for quite a while until i got to the right person in the tech department - i was very clear about what model i was dealing with too, so there was no confusion
they were VERY clear about using ONLY phosphate free coolant, and that they would absolutely void any warranty of any coolant system part if it was not used - they were actually pretty abrupt about it
having now seen a dozen or so radiators that used tap water and/or other coolant, and the owner of the country's biggest 968 shop having seen a lot more than that, and 100% of them were at least partially clogged, i cannot stress enough that doing anything you can to prevent that from happening is well worth the extra cost and hassle
side note: there are PLENTY of places here in the states that have extremely high mineral content water - i am in one of them here in socal
Old 08-10-2010, 06:04 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
The water in my township is very hard. I use distilled water whenever I can.
I've been using Dex-Cool. That's what was in it, that's what the shop said to use, and that's what I have laying around.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 08-10-2010, 07:00 PM
flash968's Avatar
that's what i have been running for the last 6 years too - i just yanked my radiator as a part of the supercharger project - clean as a whistle
Old 08-10-2010, 08:02 PM
Redline Racer
HondaDustR's Avatar
+1 more on Prestone DexCool. Haven't had any obvious problems with it, although I'm getting the feeling my radiator could be a little clogged, but then again it might just be the thermostat.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 08-10-2010, 08:20 PM
