Need to (gently) lap valves - correct compound?
I've removed the valves (plus springs, etc.) from my 85.5's head, and want to lap them soon - but am not sure what my best option would be for lapping compound. I want to buy local so I can do this quickly - but all the local shops seem to carry is Permatex - and the finest grit I can find in the grease-based compound is 150.
My gut tells me that I might need something a bit finer for the "gentle" lap that my valves could use - as the intake faces are quite smooth and shiny in general, with only a few varnish marks, while the exhaust faces are a bit more varnished and a bit carbonized, but still exhibit no scoring or pitting. valve seats are about the same - with no obvious pits.
There seems to be a pretty good deal online for something called Clover Lapping Compound - a two-grit (120 and 240) kit which seems to come in dry powder form set up for DIY mix with oil.
At any rate...would the Permatex 150 grit work - or should I look for something finer?
Old 08-18-2010, 05:22 PM
LonyB's Avatar
I lapped mine with the 150 grit just took it easy on the ones that needed less work, in fact for the ones that needed quite a bit more work I ended up speeding up the process using my variable speed drill. If you use this method BE CAREFUL!
FYI My 944 NA as never run better.
Lony
"In process" '86 944 NA (mine)
Wifes Beautiful silver '86 951 (birthday present from me)
Old 08-18-2010, 10:04 PM
If any of your local stores have the non wet dry sand paper, you could get a few bits of paper at whatever finer grit you want to use.. Soak it in hot water, in a bucket, then rub the two papers together to rub the grit off the paper, into the bucket, pour it through a cheap paint filter, sun dry, mix with wheel bearing grease....
"porsche it's an institution"
Old 08-20-2010, 12:15 AM
