944 wont start
I have an 85 1/2 Porsche 944 that will crank but wont start, I drove it 1 day and it hesitated slightly before starting and the next time I tried to start it it wouldnt, I changed the DME and the fuel pump for powers up when the car cranks, Im not sure what to try next, any ideas?
Old 09-10-2010, 10:24 AM
Try the search function. This gets asked once a week and there is never enough information to diagnose such a broad problem.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 09-10-2010, 10:32 AM
Proprietoristicly Refined
John_AZ's Avatar
If it drove one day and not the next...
Switch the DME/Fuel pump relay with your spare.....No spare make a jumper:
DME Relay Information and Testing
Top Back of the engine where the reference sensors connect. Wiggle the 2 wires. Check for cracks in the insulation. Clean the contacts.
Tighten the big ground on top of the bell housing and clean the battery connections. Put a piece of tape over the bell housing TDC Hole to avoid droping a nut in the clutch.
Fuel filter----when was it last changed?
Here are further ideas
Bennington Motorsports
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-10-2010, 10:52 AM
thanx 4 all the help, I ran through the different tests and found that I wasnt getting spark, the distributor wheel was burned up and I replaced it
Old 09-11-2010, 03:54 PM
