944paige
Send a message via Yahoo to 911paige
Unhappy starter removal problem
HI i just bought a 924s i was in the process of changing the starter i took the battery out. disconnected the leads from the battery to the starter removed one of the 2 bolts that hold it in place. well it looks like the other a 15mm bolt has had better days i can't get it off the open end keeps slipping off it is rounded a bit. has anyone had this problem and have a solution besides towing it to the nearest shop.. thanks any help would be appreciated.
Old 10-10-2010, 01:18 PM
choinga's Avatar
I've had good luck on several rounded off bolts with THIS kit.
Worse case, a bolt removal kit where you bore out the bolt and remove it with another bit. Just make sure you use some penetrating oil (Kroil, PB Blaster) and let it sit a while before cranking on it.
Old 10-10-2010, 01:49 PM
944paige
Thanks i will look into this ... the only problem is it dosen't show the size of the bolt in question 13mm then 19mm nothing in between... hmmm
Old 10-10-2010, 01:54 PM
IIRC it is an 18mm. Not a common size socket or wrench in everyones tool box.
Old 10-10-2010, 02:30 PM
Get a nice pair of vice grips on the bad end and crank down hard and if you can't get it loose by hand use a hammer gently to assist. You might want to heat it at the starter threads first and apply some BP blast.
Old 10-10-2010, 02:53 PM
Arizona_928's Avatar
+1.
You can always drill it out too. But that would be a last resort.
"Cobalt bits work the best."
dolor et pavor
Copyright
Old 10-10-2010, 06:50 PM
944paige
thanks ... so far i got the irwin bolt removal kit but it doesn't have a 15mm one is up to 14mm and the next bigest is 16 to 19mm next i will try to cut it out with my dremell will see. what is this bp or pb blast stuff?
Old 10-10-2010, 08:00 PM
944paige
Smile
thank god for my dremmel tool thanks for all the comments.. mission accomplished
Old 10-12-2010, 04:22 PM
