Transmission Fluid Change
Alright finally getting around to chaning the trans fluid. I got some Castrol Manual Gear fluid. This is a good brand? This is the fluid that came up on the computer when I asked the guys at Advanced Auto Parts what kind I needed. Also a friend said I might need additives for it too? Do I need anything to add to the trans fluid? Or just strait Trans fluid?
88 944 2.5L 4cyl NA Zermatt Silver CE - Daily Driver - SOLD |
does your car have a factory lsd?? (limited slip differential) meaning power is distributed to both rear wheels and not just one side. if so use swepco or redline, if not your fine with what you have.
Well I'm not sure. I have a 944 1988 4cyl 2.5L 5speed N/A Celebration Edition. How do i find out what it is?
[QUOTE=CKniht90;5588055]Alright finally getting around to chaning the trans fluid.
Don't forget to remove the top plug first & use the rigth wrench ,if you could get one of these it will make life less miserable for you.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
jack the car up from the back just enough to get the rear wheels off the ground, turn one wheel in one direction, if the oposite wheel spins in sink with the spinning wheel ( same direction forward or backward) you havd lsd. if the other wheels turns the other way than the way your turning, you have a non lsd or open differential.
Call Porsche America and ask them for the option list. They will want you to fax proof of ownership (I sent my registration) and will call you back with a list of the options on your car. That's how I found out my 951 has an LSD among other things.
I used Redline recently and it helped with a slight grind into 3rd. I'll probably grab some Swepco and change it again soon - the local PCA chapter has a discount with a supplier. I'll probably also get some BradPenn oil for the next change too. |
Redline MT 90. GL-4 rated lubes are specified for 944 trans.
brant giere 2005 996 cup 1991 964 euro cup (Larbre #28- race 1987 carrera 3.2-street/de car 1962 Austin Healey 3000 |
X100 on using Swepco 201 75W90 Trans Gear lube and Brad Penn 20W50 engine oil.
Check out the link below and it will tell the location of the sticker for all your codes and what your Option Codes mean. 944online.com - Porsche 944 Option Codes. http://www.944online.com/cgi-bin/forum/forum.cgi?board=944Talk;action=display;num=1273219 879;start=0#5 Cheers, Larry Last edited by Grandad#3; 09-29-2010 at 06:49 PM.. Reason: add |
Oops, forgot about the option code sticker, probably because some DPO painted over or removed it on my car...
James Chimney
hope it is ok to post this here, here is Clarks garage's trani fluid change Manual Transaxle Fluid Change I used a very small oil can with a pump (took for ever and it takes 3 bottles) Yes remove the top bolt first (do not drain it until you know you can refill it some say hit the bolt to "wake it up" I hit every thing on this car with WD-40 before starting to loosen up the "old stuck nuts and bolts) I believe it is a 17mm hex key head
Proprietoristicly Refined
Yes to the 2 synthetic oils mentioned above.
I use Valvoline HD gear oil. It is for our hypoid gears and will not ruin/eat the yellow metal syncros. Cheap. ![]() John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Parrothead member
+1 to the Valvoline. The Castrol will work just fine also.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Alright guys. Greatly appreciated. Pelican parts forums never fails me
"THERE IS NO SUBSTITUTE"
i tried swepco and others im sticking to valvoline good affordable stuff
porscha
whats the difference between the gl-3 and 4 its good for yellow synchros and the other not ?
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh Canada , Quebec |
Gl4 is what Porsche recommends. I used Redline MT90 and it's perfect for my S2 LSD Transaxle. I don't know the difference between gl3/gl4, but I know the difference from Gl4 to GL5 is that GL5 contains a high sulfur content.
my tranny is a little whiney at low RPM's when engaged because my PO put in a fidanza flywheel when he did the clutch...so I put in Swepco 210 (yes, 210 not 201) and love it. It's not silent, but it really quieted it down nicely (and I had tried Royal Purple, Lucas and 201 previously).
I'm sticking with 210 - a little harder to find, but worth it IMHO. I have a LSD. |
Back from Beyond
Lucas: Lord of Darkness, and I don't just mean Britcar electrics...
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
