Engine
What engines would fit in a 88 Porsche 944? Besides a Porsche Engine. And With very little modifying to make it work. Or is this a dumb question lol.
88 944 2.5L 4cyl NA Zermatt Silver CE - Daily Driver - SOLD |
meister member
Small block Chevy, LT1 V8, LS series V8 and the 3.8L V6.
Check here. 944hybrids Forum: V8 Conversions Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Parrothead member
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
yeah.. Would be nice to get a used Turbo or Supercharged 944 Engine. Otherwise a different brand engine. Something with more kick ya knw? lol
Under the car
All Spooled Up
Very little modifying? -Nothing (other than a low powered 924 2.0 engine).
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Alright. Thanks again. Would a turbo/supercharger 944 2.4 4cyl 5 speed fit in my car? or a 16valve?
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Ornery Bastard
Could you drop in a 951 engine? Sure. But you'd need to re-do the entire wiring harness and replace the DME along with it. And you'd need a turbo transaxle ($500 for a used one without the cooler and without an LSD, $1,000-$2,000 for a used one with a cooler and an LSD) along with a turbo clutch and pressure plate. Could you drop in a 16-valve engine? Sure. But again, you'd need a different wiring harness and different DME. If you went with the 2.5 litre 16-valve engine you could probably keep the same transaxle, but with the 3.0 litre 16-valve engine you'd really be better off with at least an S2 transaxle. Neither option is "cheap" in any real sense, at least not relative to what the car would be reasonably worth afterwards, but in both cases the hard points to physically mount the engines in the cars are at least all there. If you were asking if there were supercharger kits for the 944, I can't say for sure. I think there may have been some at one time, but I don't know off the top of my head if anyone is still making one. I seem to recall people thinking there were issues with the kits that used to be offered, but that may have just been gossip. If you were asking whether it would be possible to add a supercharger to a regular 944 engine, well, technically yes. I've seen some people do it, but it's not cheap, it's not a quick proposition, and because you have to keep the boost low to avoid destroying the engine, you still come out with less power than the 951. Overall, there really isn't a "cheap" option for an engine swap. These aren't like a '68 Mustang where you can drop in anything from a 4.9 litre straight six to a 7.0 litre V8 and have it all bolt up.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
hi Ernie, do you have more pics of this car? any links to its build? or pics/threads on 968 powered 944's like it?
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
Not this schit again......
a wide variety of engines can be made to fit. the most popular as stated are the chevy LS/LT v8's. they fit nicely and there is lots of documentation out there regarding that swap. that said, the 944 has a pretty good amount of room under the hood for a car its size. the biggest issue seems to be width of most worthwhile motors, but even that can be slightly worked around with some creative cutting and welding. hell, i did a rough measurement of a 454 (7.4L) chevy big block and it would (barely physically) fit in the 944 bay, but youd have to find some pretty tight tucked headers and an interesting solution for steering and brakes if you did that. that said i would like to see someone put a volvo short-6 into a 944. |
I hope you mean the stock 968 engine to break 140..... No way a stock 944 engine will...
There was an article in Excellence a while back about a man in German who took a stock 1987 924S and dropped in a 951 Turbo S engine, transaxle, and electronics. The car was lowered a bit, and the engine chipped for a bit more power.
It had a top speed of 176 MPH. And unlike a V8 conversion, there is no custom fabricated parts required. If you want the fast way to a lot of power and speed, this is it.
M |
ive done it multiple times, once in an early (aware of the optimistic cable speedo, it read 150+) and also in an '86NA on the way back from vegas and other trips (with the electronic speedo, more accurate, still read like 145) Last edited by v2rocket_aka944; 12-26-2010 at 11:08 PM.. |
Sidny like you I'm not a big fan of transplante & somewhat of a purist when it come to P cars,but if someone is asking for infos I will not hesitate to send it out.
Ornery Bastard
The car that Road & Track got up to 137 (test on 4/'89) was a 1989 2.7 liter car, not one of the early 2.5 litre 8v cars. R&T got an early car up to 132 in a test on 5/'82, but only managed 123 with a later car in 2/'86. Some of the ROW 8v cars did manage to touch 140, but those weren't carrying US-spec emissions equipment and the ROW 2.5 liter cars had a 20 hp advantage on US-spec 2.5 liter 8v cars.
Location: In a dumpster behind Albertson's in Los Angeles County
Actually the 1989 2.7 will break 140. And the electric speedo in my 88 turbo s, does actually read accruately up to 150 (on the main straight at Miller Motorsport Park), and that is radar verified
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi Last edited by 89-944NA; 12-27-2010 at 10:31 PM.. |
alright. Thanks guys. It was jus a curious question. Maybe do one of these in the future (thats if i dont find another car I like). and AaronM I ment 2.5L .. that was a typo (2.4L)
88 944 2.5L 4cyl NA Zermatt Silver CE - Daily Driver - SOLD Last edited by CKniht90; 12-28-2010 at 01:39 PM.. |
