help with injector pulse
I have an 83 944 and my fuel injectors are not firing, I am getting spark, in fact I can get the engine to run on starting fluid. I pulled the injectors out and tested them directly off the battery, and they fired and sprayed just fine, so I am sure its not an injector issue. next I tested the electrical wires going to the injectors, each injector was the same story, were both wires going to the injector were putting off a constant 12v. is this how it should be? if not then how should it work.
I also have a new DME relay in it.
Old 01-19-2011, 02:23 PM
yarfk
kfray's Avatar
The 4 fuel injectors have 12 VDC supplied to one pin and the DME Computer output pin 15 and 14 pulse to ground on the second fuel injector pin.
I would check the speed and reference sensors.
http://www.clarks-garage.com/pdf-manual/ign-02.pdf
If Sensors check OK the check the DME computer:
http://www.clarks-garage.com/pdf-manual/dme-01.pdf
http://www.clarks-garage.com/pdf-manual/dme-02.pdf
Once the DME computer is open check for bad solder joints
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 01-19-2011, 04:32 PM
so the hot wire pulses to ground to create a circuit to fire the injector?
Old 01-19-2011, 04:47 PM
North Coast Cab's Avatar
Yes
1985.5 944 GTS
Old 01-19-2011, 05:29 PM
Used & Abused
The injectors are fed with constant hot +12. Ground is pulsed on and off to fire the injectors.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 01-19-2011, 05:33 PM
yarfk
kfray's Avatar
One pin of the injectors are supplied 12VDC, the 12VDC is connected to a coil inside the injector, other side of the coil is connect to the second pin of the injectors and is pulsed to ground by the DME Computer.
Old 01-19-2011, 05:47 PM
so both wires are suppose to be 12v, and the computer pulses one of them to ground?
Old 01-19-2011, 06:02 PM
yarfk
kfray's Avatar
Yes
Old 01-19-2011, 06:33 PM
sounds good, thanks for the help
Old 01-19-2011, 07:13 PM
