-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Replaced brake pads anything needed between (http://forums.pelicanparts.com/showthread.php?t=585604)
zog1 01-15-2011 06:36 AM
just got new rotors and pads from pelican, they look great, but is there anything needed between the new pad and caliber for noise, nothing was in the box and the direction did not say
rick13 01-15-2011 07:27 AM
just curious..what kinda noise are you getting?
billy mild 01-15-2011 07:33 AM
Make sure to clean off any hardware really good. If it is rusty just replace it. Also use brake lubricant where its needed. Put some lubricant on the back of the pad or just use some of the redish orange brake quiet from auto parts store. This will make sure there is no noise at all when braking like my car. It squeels like mad because whoever did the brakes last time didn't do what I just outline above.
John_AZ 01-15-2011 07:34 AM
Grease on all metal contact points.
http://forums.pelicanparts.com/uploa...1295105359.jpg
Check your caliper rubber dust covers for rips/cuts. I just rebuilt my front 2 on the '88. If your rubber is torn, rebuild/reseal the calipers before you flush the brake fluid. Should be done every 2 or 3 years. DOT 4 Super Blue from Pelican.
If you are doing the front----New seals for the wheel bearings. Repack the wheel bearings. Adjust play in the front wheel bearings.
GL
John
zog1 01-15-2011 07:35 AM
I haven't finished changing all pads and rotors yet, so no noise, but on other cars I've done there were clips or antiviberation compounds in with the new pads, but these Textars had nothing
zog1 01-15-2011 07:53 AM
thanks for the help and will get the brake lub
Techno Duck 01-15-2011 08:11 AM
You dont really need any of that goop on the Brembo's (i am assuming your car is a 951 based on your garage entry). There are stick on clips that anchor the brake pad into the piston bores but i have found they are not necessary and just make changing pads require removal of the caliper (which is easy..but why go through the extra work for nothing).
I have never really had problems with squealing or noise on a normal street pad (track pads are a different story.. you can hear my stopping from a mile away), the most important thing is to bed the pads in correctly.
zog1 01-15-2011 08:24 AM
I just picked up this 944T(951) about a month ago(and love it,1st porshe), there were not any clips on the pads and maybe previous owner removed them also, but what do you mean by Brembo, caliber?
Techno Duck 01-15-2011 09:10 AM
The 951 has calipers made by Brembo.
These are the stick on dampers i was talking about, in my experience not worth the trouble.
Brake Pad Vibration Damper
Rasta Monsta 01-15-2011 02:52 PM
Slowly place the wrench on the ground, and step away from the car. . .
Arizona_928 01-15-2011 08:39 PM
Originally Posted by rasta monsta (Post 5786275)
slowly place the wrench on the ground, and step away from the car. . .
+1
zog1 01-18-2011 09:42 PM
you can't learn by walking away from thing
nzporsche944s2 01-18-2011 11:10 PM
Rasta - you really make me laugh. I'd love to have a drink with you one day if this is what you are like sober....
fiat22turbo 01-19-2011 12:18 AM
He is.
pjs77 01-19-2011 06:29 AM
hahaha Rasta, that is funny and I know you are just busting chops but give the guy a break, he's had the car a month and it's his first. There was a time when you had never heard of brembo...
Rasta Monsta 01-19-2011 08:38 AM
Sold!
Slam 01-19-2011 10:01 AM
If you're gonna be drinking for heaven's sake come and do it up here! Or at the very least have 2 or 3 for me and all the other poor saps stuck out here in redneckland.
IIRC, Rasta's an herbalist also...
John_AZ 01-19-2011 11:41 AM
What makes Rasta unique is that others may have suggested: RTFM.
Here's to Rasta
http://forums.pelicanparts.com/uploa...1295466007.jpg
John
nzporsche944s2 01-19-2011 11:52 AM
Rasta - find your way to New Zealand and the beer is my shout
