Replaced brake pads anything needed between
just got new rotors and pads from pelican, they look great, but is there anything needed between the new pad and caliber for noise, nothing was in the box and the direction did not say
Old 01-15-2011, 06:36 AM
just curious..what kinda noise are you getting?
Old 01-15-2011, 07:27 AM
Make sure to clean off any hardware really good. If it is rusty just replace it. Also use brake lubricant where its needed. Put some lubricant on the back of the pad or just use some of the redish orange brake quiet from auto parts store. This will make sure there is no noise at all when braking like my car. It squeels like mad because whoever did the brakes last time didn't do what I just outline above.
Old 01-15-2011, 07:33 AM
Proprietoristicly Refined
John_AZ's Avatar
Grease on all metal contact points.
Check your caliper rubber dust covers for rips/cuts. I just rebuilt my front 2 on the '88. If your rubber is torn, rebuild/reseal the calipers before you flush the brake fluid. Should be done every 2 or 3 years. DOT 4 Super Blue from Pelican.
If you are doing the front----New seals for the wheel bearings. Repack the wheel bearings. Adjust play in the front wheel bearings.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 01-15-2011, 07:34 AM
I haven't finished changing all pads and rotors yet, so no noise, but on other cars I've done there were clips or antiviberation compounds in with the new pads, but these Textars had nothing
Old 01-15-2011, 07:35 AM
Thumbs up
thanks for the help and will get the brake lub
Old 01-15-2011, 07:53 AM
That Guy
Techno Duck's Avatar
You dont really need any of that goop on the Brembo's (i am assuming your car is a 951 based on your garage entry). There are stick on clips that anchor the brake pad into the piston bores but i have found they are not necessary and just make changing pads require removal of the caliper (which is easy..but why go through the extra work for nothing).
I have never really had problems with squealing or noise on a normal street pad (track pads are a different story.. you can hear my stopping from a mile away), the most important thing is to bed the pads in correctly.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-15-2011, 08:11 AM
I just picked up this 944T(951) about a month ago(and love it,1st porshe), there were not any clips on the pads and maybe previous owner removed them also, but what do you mean by Brembo, caliber?
Old 01-15-2011, 08:24 AM
That Guy
The 951 has calipers made by Brembo.
These are the stick on dampers i was talking about, in my experience not worth the trouble.
Brake Pad Vibration Damper
Jon
Old 01-15-2011, 09:10 AM
Toofah King Bad
Rasta Monsta's Avatar
Slowly place the wrench on the ground, and step away from the car. . .
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-15-2011, 02:52 PM
Arizona_928's Avatar
Originally Posted by rasta monsta View Post
slowly place the wrench on the ground, and step away from the car. . .
+1
dolor et pavor
Copyright
Old 01-15-2011, 08:39 PM
you can't learn by walking away from thing
Old 01-18-2011, 09:42 PM
Rasta - you really make me laugh. I'd love to have a drink with you one day if this is what you are like sober....
Old 01-18-2011, 11:10 PM
fiat22turbo's Avatar
He is.
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 01-19-2011, 12:18 AM
pjs77's Avatar
hahaha Rasta, that is funny and I know you are just busting chops but give the guy a break, he's had the car a month and it's his first. There was a time when you had never heard of brembo...
Paul - Norwell, MA
1985.5 944 Guards Red N/A
Koni Sports, S2 sway bars
Old 01-19-2011, 06:29 AM
Toofah King Bad
Sold!
Old 01-19-2011, 08:38 AM
Back from Beyond
If you're gonna be drinking for heaven's sake come and do it up here! Or at the very least have 2 or 3 for me and all the other poor saps stuck out here in redneckland.
IIRC, Rasta's an herbalist also...
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 01-19-2011, 10:01 AM
John_AZ's Avatar
What makes Rasta unique is that others may have suggested: RTFM.
Here's to Rasta
John
Old 01-19-2011, 11:41 AM
Rasta - find your way to New Zealand and the beer is my shout
Old 01-19-2011, 11:52 AM
