Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Manual steering - tie rod install question
I've done a manual steering rack conversion on my race car and am in process of installing the new tie rods. I have purchased Moog 378 inner rods and kept the later model outer ends. Just eyeballing the wheels straight I end up with about 20mm (3/4") of thread engagement on each tie rod end. Is this enough to hold a race car together?
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-30-2011, 02:28 PM
The rule of thumb for strenght & threads is,
For male & female threads of same material, the male part will wring off or brake by tension before the threads pull out.
from memory the threads are about 14mm or 1/2". 3/4" engagement ought to be good if it is under the clamp on adjusting tube.
drew1
wife has 924 turbo
Old 01-30-2011, 03:12 PM
yarfk
kfray's Avatar
There are different part numbers for manual and power steering outer tie rod ends
Porsche 924S/944/968 Steering System - Page 2
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 01-30-2011, 05:15 PM
Stahlwerks.com
jhelgesen's Avatar
I have a conversion using the moog 378 tie rod inners for a vw golf and the power steering outers. Stock manual tie rod assemblies are too short for a late model suspension.
Old 01-30-2011, 05:33 PM
