hobiecat's Avatar
Weird Crankshaft question
I'm in the process of building up a replacement engine for my track/DE 944S.
I bought a used engine with 55,000 on the odometer. Upon inspection, it shows no signs
of significant wear anywhere....totally consistent with an engine with low mileage. So...because
I figured it wouldn't be a bad thing to do, I put the engine on a stand, took off the oil pan (to install
a pan baffle) replaced the rod bearings and was in the process of installing a crank scraper when
I noticed something very interesting.
The crank moves.... laterally....front to back. More than I would expect. So far, in fact, that if I push as far
as it will go to the rear, the #4 piston rod rubs against the back of the block. When I push it forward,
everything is lined up perfectly....even the crank scraper. Move it back....no go.
So...given the low (documented) mileage on this motor....do I have an issue here, or is this normal?
Considering there are not any (ZERO) marks inside the block that would lead me to believe that #4 is
rubbing on the back of the block, nor were there shavings or scratches anywhere else, is there
some explanation for this? Clearly if this was a problem before I got the motor, it would've
manifested itself in some way....I'd see some damage somewhere....right?
Has anyone else seen a similar issue? The engine is in really great shape....I just don't want to button
it up if I'm going to have to replace something deeper in the block. Make sense?
Jim B.
Maryland
1987 944S - Black #303
2004 VW Golf R32 (daily ride)
Old 02-10-2011, 04:01 PM
Proprietoristicly Refined
John_AZ's Avatar
I am not sure what the tolerances are. Maybe check the WSM?
This explains the issue:
CRANKSHAFT END PLAY & THRUST BEARING HEALTH
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 02-10-2011, 04:52 PM
John_AZ's Avatar
Crankshaft tolerances
John
Old 02-10-2011, 04:55 PM
