Few Questions
I have a 86 944 na Has been hit a few times The interior engine, transmission are great
I found a 84 944 na. What can i use as a upgrade How hard is a dash swap? will my carpet work, 86 door panels fit the 84 without the dash swap? Will my dme work? |
Here is what I know. The driveline will transplant but you should use the DME and the AFM from the 86. The dash swap is supposedly a beast to accomplish and I know nothing of the door panels but I suspect there are differences as the window switches and inside door handles are different.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
