Shift knob adapter
This look like a great idea for adapting a different shift knob to your 944s without to much hassle ,does anybody here has use these before & if so how good are they. 928 Motorsports - From Road to Race, 928 Performance is 928 Motorsports® Once on the site use the Search & enter (shift knob adapter) they also have other items for our cars under (944/951/& 968 Items).http://forums.pelicanparts.com/uploa...1300929245.jpg
http://forums.pelicanparts.com/uploa...1300929314.jpg |
Used one briefly, a bit annoying as the shift knob 'buzzes' on occasion because its not a perfect fit onto the Momo knob. The shift rod transmits a ton of vibration and the factory setup really does a good job of dampening it. Make sure you loctite the set screw for the shift knob in also.
I mad my own for a new Momo shift knob out of 1/2" copper water pipe and it worked great but copper being soft if slowly loosened up so I bought one of those and it worked but I then upgraded to an adjustable shift linkage ("short shift linkage") under the shift knob and it fit better but has a very bad vibration, not enough room for even black tape and will have to find some thing as a spacer
| All times are GMT -8. The time now is 12:09 AM. |
