83 944 NA A/C Compressor mounting Access
I am about to re-mount the A/C Compressor on my 83 944. Purchased last August and have had A/C, Alternator belt noise since. I discovered the aft bolt and sleeve were missing. My question is: would there be any benefit to pulling the Air Cleaner housing to gain access from above?
Thanks, Mike |
Been a while but my rear bolt on the a/c mount was missing. i thin its possible to thread the bolt in by hand from the rear while under the car but i think i had to go from above to tighten the bolt down. I don't have the stock filter any more so im not 100% if i had to go from above.
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
Make life easier for yourself __remove the air box,then disconnect the J boot at throttle housing ,remove both J booth & AFS (air flow sensor).This way you'll have easy access to the A/C compressor from the top if needed, which I believe you will.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Self-Proclaimed Newb
^^ +1
When I bought mine in November, one of the bolts mounting the compressor to the alternator was shorn off inside the hole. Had no jack, so the only way to get to it was from above; now, I can say with certainty that's the best way to go. Now, if your compressor mounting bolts ever decide to unscrew themselves while you're driving along on the freeway and your compressor drops, suspended only by the hoses it's attached to, *then* you'll be wishing you had a cone filter so you could just re-mount it quickly at the end of a one-way street before the thunderstorm comes. That was one hell of a night.
