-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Engine shakes the cab at idle.. but why? (http://forums.pelicanparts.com/showthread.php?t=602729)
John_AZ 04-14-2011 09:22 PM
Originally Posted by AA_Ezra (Post 5964541)
John do you have all these post's bookmarked or is it just from memory that you search for the post
Ah,
yes ;)
John
v2rocket_aka944 04-14-2011 09:23 PM
balance shafts dont do a whole lot at idle speed; they are most noticeable at higher rpm. the shaking is definitely the motor mounts. also you can raise your idle speed to smooth it even more.
AA_Ezra 04-14-2011 09:40 PM
Idle is at 800-850 when i start been a while since I've checked it at normal temp As that's almost impossible bc I have a low temp thermostat and fan switch.
Anyways, so what you're saying is that if it was a really bad balance shaft issue like 180degrees off I would notice it at high rpm's as that's when it's at it's worst?
v2rocket_aka944 04-15-2011 09:05 PM
if balance shafts are out of time then you will notice the vibration at most speeds because how the harmonics stack up. but when they are timed correctly you wouldnt notice them really doing much til around 3000ish+ rpm.
set idle to 950 or 1000 or so, it should smooth out noticeably
AA_Ezra 04-15-2011 11:09 PM
Well that makes me feel better, Been a while since i have drivnen it but anything above 1000rpm it runs smooth. Haven driven the car in 6 months but even then 1000-4500 rpm it runs smooth.
I am afraid of a vacume leak wich i wil have to check. Anybody know what the PSI vaccume should be?
John_AZ 04-16-2011 05:20 AM
I have a link ---"yeah, surprise, surprise ;)"
Move down and click on the "scenarios".
How to Use and Interpret a Vacuum Gauge
GL
John
mikepellegrini 04-16-2011 08:27 AM
GL
John
That's a really good site, John.
So good it inspired me to go buy a vacuum gauge. It's a really good, basic diagnostic tool.
AA_Ezra 04-16-2011 09:14 AM
GL
John
LOL, that's awsome john Don't go away any time soon.
according to that test i might be able to tell if the noise i hear in my cam is
A. Weak or broken spring
B. Just the lifter
Sure beats taking the motor apart :P
I'm sure you have done this yourself already, Any tips on were to hook it up?
I was thiking the vaccume at the throttle body as my Brake PVC is old and on there scary tight
John_AZ 04-16-2011 05:07 PM
Mike,
Thanks.
You and your son amaze me with the work you do on the cars.
You and I know there are members who could use his help and pay for his college or Porsche internship (in Germany of course).
Jaime O.
"Plug and Play" :)
John
AA_Ezra 04-17-2011 10:12 AM
What do you think abotu this. I've been searching everywere and a similar idea came up. The car in the video is a turbo so i assume the vacuume hoses will handle more psi?
I was thinking maybe using 5-10 psi?
YouTube - DIY - how to pressurize your 944 turbo intake system
on a side note THE OAS tope tube does not require a hose fitting but i put one on a littel snug on mine is it commong to have a little what seems like oil sray around the top of the OAS?
p-talk 04-20-2011 08:28 AM
Here's a new trick to smooth out the motor - try some Lucas Fuel Treatment next time you fill up. I tried it for the first time last weekend (after seeing this discussion), and it did smooth out the motor quite noticeably.
Don't get me wrong - I'll still be trying the idle adjustment trick, and I do still need to comb through my vacuum system, but the Lucas did really really help.
AA_Ezra 04-20-2011 08:49 AM
Well, Im sure the old gas in the car isen't helping, And it's sad as i just rebuilt/cleaned the injectors. Probly toss some seafoam in the tank instead as i have a bottle sitting right here.
And BTW the home made vacuum pressure tester i made with some soapy watter works great. Found a few vacuum leaks fixed most by tightening clamps but My aux air valve is leaking at the top were the harness conects Seems like a weird place and might be the cause of our Mysterious leaks as it was a very large vac leak
AA_Ezra 04-21-2011 01:54 PM
pulled off my Injector rail and j-boot to seal up some vacuum leak... and
HOLY GUACAMOLE. One of my injectors is leaking and was eating up the nice paint i put on it. And i just rebuilt the damm thing.
Possibly another symptom of why my car was shakign?
