"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
Porsche Crest how to adjust shift linkage?
After doing my clutch i notice going in to second gear is kind of rough, how do you adjust the linkage?
1986 Porsche 944 2.5
2004 Jeep Grand Cherokee Limited 4.7 H.O.
2000 Plymouth Neon
Old 05-04-2011, 07:47 AM
Proprietoristicly Refined
John_AZ's Avatar
1. Get a new shift lever and White plastic cup under shift lever.
2. Tighten carefully all linkage bolts by the transaxle.
3. Check to see if your rear linkage is per Clarks
Transaxle - Checking, Repairing, and Replacing the Shift Lever and Shift Linkage
If the white plastic piece on top of the transaxle is worn=NLA Bottom picture in link.
I have used thin shims to improve shifting on the "intermediate shift lever"
Your shift lever may have deformed the hole in the shift rod. Again you can shim.
If so, link available.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-05-2011, 01:08 PM
