"Ferdinand's finest"
lowenschlo's Avatar
Thumbs up Best 944 NA upgrade possible under $500?
Hello all,
just would like some recommendations on either a performance, or exterior/ aesthetic upgrade under $500 that would make an astounding improvement overall depending on which department it falls under. Thanks a bunch!!!
Cheers,
Drew
Old 05-26-2011, 09:09 AM
$500 worth of summer tires
Old 05-26-2011, 09:13 AM
lowenschlo's Avatar
Already taken care of!
Old 05-26-2011, 09:16 AM
Drivers school / track day
Old 05-26-2011, 09:21 AM
In the Fires of Hell.....
kdjones2000's Avatar
New throttle cam!
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 05-26-2011, 09:29 AM
lowenschlo's Avatar
Would that just improve response or do more then that?
Old 05-26-2011, 09:58 AM
Custom User Title
mikepellegrini's Avatar
Koni's.
Old 05-26-2011, 11:04 AM
after tires, koni's.
after koni's....w/o sacrificing ride comfort....50shot of nitrous.
Old 05-26-2011, 11:14 AM
ernie9944's Avatar
Simple a good tune up,new wires Bosche OE/spark plugs(the rigth one for your car)dist cap & rotor.then a MSD Blaster coil,short shifter & throttle cam (doesn't do anything power wise but nice respond)LOL do we have any money left. if so s/s brakes lines.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 05-26-2011, 11:28 AM
Non Compos Mentis
+1, +2 and +3.
This will vastly improve the 944 and everything else you drive for the rest of your life.
Old 05-26-2011, 11:36 AM
Proprietoristicly Refined
John_AZ's Avatar
Here is how to spend the first $500 ---take your pick...
eBay Guides - Porsche 944 968 Modifications and Repairs
After you have these done go for the upgrades.
Porsche Doc is a pro mechanic and does this for a living.
944 HP Questions/Answers - Porsche Forum - Porsche Enthusiast Forums
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-26-2011, 11:39 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Definitely track time. After that I'd say freshen up the suspension and brakes.
Black Cars Matter
Old 05-26-2011, 11:57 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
If you are doing the work (DIY) then Turbo/Brembo brakes all around - great improvement to a NA car.
Used MAF system with chip - these though, for a Na car, are hard to find used, but a great upgrade.
Timing/balance shaft belts and rollers when due can be done DIY for under $500
$500.00 worth of stereo - wow.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-26-2011, 12:03 PM
Misunderstood User
Put bulbs/sockets in the empty locations on the rear tail lights. If you have done tires, brakes and Koni's, put bigger sway bars F&R from a 951. Modify your stock throttle cam.
I
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
if you do a clutch job put on a fidanza AL flywheel(more power on rear axle,faster revs)
or
try to get front and rear hub/brakes from a turbo or S2 depends of your offset
or
put a rear stabilizer bar(if you not have it),new shoks,tires,
or
put the money apart for next maintenence and put new OEM parts like fuel dampers,presure regulator,O2 sensor,rubber intake hose.....
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 05-26-2011, 01:23 PM
rickharrison's Avatar
Depending on year of car...the Miller Performance MAF kit...do a search. $399 with chips, etc.
Dyno gains 10% HP and TQ.
...oh, and +1 to others that have quoted...
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 05-26-2011, 05:22 PM
Seat time...I agree is the best. If you are going to that anyway. Everything depends on how you want to drive and what you are after. For me it was autocross and Time Trials. Here is what I did.
Race seat and harness: Its interesting how well you can work on actually driving, when you are held securely in a good fitting seat. I got a used set for $200 total.
Suspension: Upgrade your sway bars. A used turbo bar can be had for $100 or so. Konis or Bilstein Sports are great upgrades. From there, a coil over set up for the front with better springs. I picked up a use ground control set up with #350 springs for $120. Or the Weltmeister #250's which fit in the stock perches. I sold mine for $75. Bigger Torsion bars, you can get Porsche specific or locate a good VW supply...the Super Beetle torsion bar is the same fitment as a 944 at half the price.
I have done nothing at all to the engine to modify it. I was at Chuckwalla Raceway last weekend at a Time Trial. Its so satisfying to get a point by from folks in cars with 100+ more HP. :-)
Old 05-26-2011, 09:23 PM
Buy a POS 944 for $500 and gut it of everything. A 2400 lb 944 would be a blast.
Jackson
Old 05-26-2011, 09:52 PM
lowenschlo's Avatar
thanks im getting some ideas........I REALLY the miller MAF kit, but io have an early 85 NA, will this be an issue??
Old 05-27-2011, 02:39 AM
u'll have to swap to a late DME and late AFM
Old 05-27-2011, 07:03 AM
