lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Red face Front End update
Ok it's finally time to bite the bullet and pull apart the front end. I'm going to replace the front bushings, and shocks and possibly upgrade the springs. I don't really want to change the stock ride height, but I do want to tighten up the ride (daily driver, no racing). I'm going to do most of the work myself, probably followed by a professional alignment. What is my best bet if I don't want to spend an arm and a leg? I was looking at Boge/Sachs inserts/shocks with 220 lb H&R springs. Do I need to install snubbers as well? Should I think about replacing the sway bar or rear torsion bar? Thanks. It'll be a long road to make my junker a curb queen, but I'm finally getting some free time to get the work done.
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 03-12-2002, 12:30 PM
