-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Right side light dont work anymore (http://forums.pelicanparts.com/showthread.php?t=630939)
alpom 09-21-2011 04:52 PM
Hello,
i have lost my front bumper when going back in my garage. wires were still plugged and the bumper was still on the car on the left side.
I unplugged all the wires and went at the body shop.
I plugged back everything but now only the fog,the driving light and the brake lights are working on the right side. the 2 yellow on the front are not working and the night red back light is not working as well.
The left turn signal go really fast on day mode and on night mode its going 2 time faster and normal speed when brake is on.
what's the problem?
thank you
alex
alpom 09-23-2011 01:35 PM
nobody can help?
John_AZ 09-23-2011 01:48 PM
All of the bulbs have to be in sockets---even the damaged bumper lights.
If they are all in, usually rapid flashing means one is burned out. Check that all are good.
If none are burned out, check the sockets that were in the damaged area.
Check the grounds where the damage happened. Maybe the ground wires are not attached.
If all looks good in the damaged area, one of the other turn signal bulbs is burned out.
If this cannot fix the rapid flash, it might be the flasher--normally not.
GL
John
Dawgz83948 09-23-2011 02:07 PM
On the early 944's the left and right side of the car are a seperate fuse. I don't recall if thats the case on the late cars too.
alpom 09-24-2011 08:57 AM
fuse ok,
bulb all ok
maybe (probably) the ground!
where is it in the right side of the harness?
cause front and rear lights doesnt work, so it must be in the harness.
John_AZ 09-24-2011 09:25 AM
Ground pic:
http://forums.pelicanparts.com/uploa...1316881505.jpg
alpom 09-25-2011 02:06 PM
thank you
