alpom's Avatar
Right side light dont work anymore
Hello,
i have lost my front bumper when going back in my garage. wires were still plugged and the bumper was still on the car on the left side.
I unplugged all the wires and went at the body shop.
I plugged back everything but now only the fog,the driving light and the brake lights are working on the right side. the 2 yellow on the front are not working and the night red back light is not working as well.
The left turn signal go really fast on day mode and on night mode its going 2 time faster and normal speed when brake is on.
what's the problem?
thank you
alex
Alfa Romeo Spyder veloce restored for SALE
Porsche Black 951 restored (engine, trany, body, etc) SOLD
Porsche Black 911 1993 race car cage not finish 3.6 (SOLD)
Porsche grey 911 1970 E (SOLD in pieces)
Old 09-21-2011, 04:52 PM
alpom's Avatar
nobody can help?
Old 09-23-2011, 01:35 PM
Proprietoristicly Refined
John_AZ's Avatar
All of the bulbs have to be in sockets---even the damaged bumper lights.
If they are all in, usually rapid flashing means one is burned out. Check that all are good.
If none are burned out, check the sockets that were in the damaged area.
Check the grounds where the damage happened. Maybe the ground wires are not attached.
If all looks good in the damaged area, one of the other turn signal bulbs is burned out.
If this cannot fix the rapid flash, it might be the flasher--normally not.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-23-2011, 01:48 PM
Dawgz83948's Avatar
On the early 944's the left and right side of the car are a seperate fuse. I don't recall if thats the case on the late cars too.
Old 09-23-2011, 02:07 PM
alpom's Avatar
fuse ok,
bulb all ok
maybe (probably) the ground!
where is it in the right side of the harness?
cause front and rear lights doesnt work, so it must be in the harness.
Old 09-24-2011, 08:57 AM
John_AZ's Avatar
Ground pic:
Old 09-24-2011, 09:25 AM
alpom's Avatar
thank you
Old 09-25-2011, 02:06 PM
