weird growling when accelerating on about 5000rpm
I think the noise is coming from transmission hitting the body but if not, does the clutch shaft has bearings and does they make sound even on normal drive if they are bad?
white 81 924
Old 10-11-2011, 11:59 PM
weird..
someone replied but there is no message here...
but there is transmission mounts on the back of the transmission too..
like those
this is the email I got:
Here is the message that has just been posted:
it is called a transmission mount, and they are fairly easy to change...there is just one of them, located over the top of the transmission. The transmission actually hangs from the mount.
white 81 924
Old 10-12-2011, 12:27 AM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Make sure your exhaust isn't touching the car also.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 10-12-2011, 07:05 AM
