924S front engine lifting eye
I searched for 10 minutes for this pesky thing all around the J Boot area but cannot find it.The rear eye is obvious but I need the front one to suspend the engine from to facilitate dropping the oil pan.
Can someone please send a photo of the thing and its location(the online Porsche engine manual photo isn't clear enough and I cant seem to enlasrge it). The engine has never been out of the car, the head has never been off, so surely it should still be in place, or is it something one has to buy and bolt on?
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
It's underneath the J boot on top of your alternator.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Politically Incorrect
According to the FSM, you remove the belt cover breather hose and unplug the AFM and there it is below!
Edek '87 924S '91 535i |
A better view.
Funny you mention this,my 87 924S is missing the front lifting eye too! My 83 and 88 944's have them though? Maybe it was a cost cutting measure ??
I think someone just took them off,great set-up for good lifting ,the balance is spot on.
Nice detailed motor ernie was that yours?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Thanks guys, I will look for it again this weekend. it is way down the side of engine though, didnt think of looking there. Just got a secondhand engine support beam off eBay so toolwise I'm good to go I hope.
Found the lifting eye thanks for your help everyone. I also saw a sheet metal shield justbolted onto the front of the bellhousing.-do I need to remove this to facilitate oil pan removal?
The engine support beam rubber feet are just too thick for the gutters but the will stand on the wing bolt heads. Do I need to shave the rubber back or is it sufficient to perch the feet on two bolt heads each foot? Or should I make wooden packing pieces the height of the heads for under the feet in order to spread the load more?..
bump for 2 further questions
bump
Comeau Racing
We mount the engine support just inside the fender "gutters."
I think you're talking about the black sheet metal shield that covers the front of the flywheel? If it's in the way, it's just 2 or 4 17mm head bolts, depending on how it was left the last time.
PCA since 1985 77 924 MARTINI Edition rescued,SOLD 88 924S Special Edition rescued,SOLD Comeau Racing Enterprises, Inc. www.comeauracing.com We do only 924S, 944's, 968's all day, every day. |
Yep, it is the flywheel shield, so off it comes!!
