speedometer question
i noticed my speedo is off 7 mph. i am doing 107 when my speedo reads 100. stock wheels, stock tires. odometer is broken.
suggestions, comments?
rick
1988 944 turbo
Old 10-23-2011, 03:31 PM
Send a message via AIM to MPitt
I just replaced the odometer gear in my 86, and when you get the speedo out you can see how easy the needle is to move. If it's steady 7 mph difference at any speed, or if it sits above 0 when off, you might just need to adjust it.
1984 Porsche 944
1986 Porsche 944 Turbo
Old 10-23-2011, 11:36 PM
Proprietoristicly Refined
John_AZ's Avatar
rick
How are you measuring your MPH at 100-107? GPS?
Be careful with the needle:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/330607-i-think-its-broke.html
Since your odometer is broken, send the entire guage to a professional repair shop for repair and calibration.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-24-2011, 05:21 AM
Mpitt, I like your confidence.
John, I am using gps. It is a constant 7 mph.
I guess I will take it apart, and go from there. I will report back from the "deep waters"
Rick
1988 944 turbo
Old 10-24-2011, 09:29 AM
