-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   speedometer question (http://forums.pelicanparts.com/showthread.php?t=636166)
rick13 10-23-2011 03:31 PM
i noticed my speedo is off 7 mph. i am doing 107 when my speedo reads 100. stock wheels, stock tires. odometer is broken.
suggestions, comments?
rick
MPitt 10-23-2011 11:36 PM
I just replaced the odometer gear in my 86, and when you get the speedo out you can see how easy the needle is to move. If it's steady 7 mph difference at any speed, or if it sits above 0 when off, you might just need to adjust it.
John_AZ 10-24-2011 05:21 AM
rick
How are you measuring your MPH at 100-107? GPS?
Be careful with the needle:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/330607-i-think-its-broke.html
Since your odometer is broken, send the entire guage to a professional repair shop for repair and calibration.
GL
John
rick13 10-24-2011 09:29 AM
Mpitt, I like your confidence.
John, I am using gps. It is a constant 7 mph.
I guess I will take it apart, and go from there. I will report back from the "deep waters"
Rick
