Replacement for a spark plug wire set for a 944s 87
Hi, I am looking for opinions about the better brands or choices to replace the spark plug wire set for my Porsche 944s.
Please help me. Pepineco ( from el Salvador) ![]() ![]() ![]()
[QUOTE=Pepineco;6357359]Hi, I am looking for opinions about the better brands or choices to replace the spark plug wire set for my Porsche 944s.
Please help me. First welcome to Pelican one of the best forum to get help from.Spark plugs wires are one of the most important parts on your car so don't hesitate to pay a little more & get a quality set.I usually recommend Bosch Silicon OEM since they serve me well for a number of years on my ex 944.But there is also other brand such as Beru got them on my 968 rigth now with over 50Kmiles on them & are still going strong.Beru will cost you approx $145.00 for the set including coil,you can get them here from our host Pelican part#is 10-8533-614-M47.They also have another brand call Karlyn a little cheaper $104.25 but don't know them.For Bosch you may try this place Discount Auto Parts Online - Import Auto Parts -- *********.com the last time I check they were around $95.00 a set.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Forgot to ask you ,is your car a 944S 16V ,because if it is, price mention in my previous reply will be different.
New prize for an 87 944S will be Karlyne-STI $158.75-Bosch OEM $120.94 & Beru the most expensive at $214.94.___Pepineco those are only suggestion on brand ,it will be up to you to shop around & decide what you want to buy.
I read a service builiten in the back of the factory 944 parts catalog that said something about the 16v engines and the sparks jumping to the bottom of the hood from the wires unless the car has the proper hood insulation. Just something to think about. Oddly enough, the S2 cars dont have any hood insultation. Jackson |
Basket Case
It was fitted with a set of non-standard Bosch spark plugs that had metal "boots" to connect to the spark plugs. These boots were longer than standard and could definitely lead to some shorting problems if located where the plugs are in a 16V without hood insulation. Just food for thought.
1983 Porsche 944 "The Captain" - Project for 2013 Targa Tasmania |
Will Magnecore work on a 944S? I have read on the board they are the best replacement wires available. They make an 8.5mm wire.
If one want to get in the fancy stuff Paragon Products - Porsche Parts & Accessories - Koni, Pagid, K&N, Bilstein, Racers Edge, Weltmeister, Porsche suspension, porsche brakes, 911 parts, 944 parts, 968 parts, 914 parts, 930 parts, boxster parts, cayman parts, 968, cayenne has 8mm spark plugs wires for the 16V,it feature the original Beru connectors that fit properly & have the proper resistance, available in Red/Yellow or Blue prize quote is $170.00.I know some 968 owners that went with them & up to date are very satisfy
Toofah King Bad
Kingsborne.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Thanks for the help, If I will not find this type of wires in the local market, I will buy on line.
One more question, that´s replacement brands like Bosch or Beru are compatible with a Audi Spark Wire, this result because in my country there no more than 6 944S all around the country. Thanks for the help and enjoy your´s Porsche.... Pepineco |
