Mein Gott!
Panzer909's Avatar
High beam works......low beam does not.
I noticed that my right headlight was out yeasterday. Thinking that the bulb was done, I was just going to get another one, but noticed that the hight beam works fine, as does the "flash" beam.
Just the standard low beam is out altogether. Anyone had this happen to them? What da???
Old 04-04-2002, 10:12 AM
The High beam and Low beam use different filaments. In your case the low beam filament has burned out. All you need to do is replace your headlight. I would recommend replacing both the right and left side together. This also might be a good time to upgrade your headlight to H4 lighting. Hope this helps.
Old 04-04-2002, 10:25 AM
Mein Gott!
Panzer909's Avatar
Helps a lot thanks.
Yeah, I was considering the H-4 route anyways as the stock lighting rivals most hand-held flash lights. Off to the parts store I go.
Old 04-04-2002, 02:17 PM
