darnellsgarage
Question black plastic skirts
As said in ealier post, car back from paint and I am in re-assembly mode.
In removing the four pieces of black plastic between the wheels, I broke off nearly all of the bolts holding it on. I think they are just studs, and then they were kept on by plastic bolts or something of that nature. I was thinking of just grinding off the rest of the bolt and then drilling it out for large metal screw.
Anyone else done this, and how did you fix it?
don
Old 01-01-2012, 10:49 AM
That Guy
Techno Duck's Avatar
If i remember right the fasteners on the body are all speed nuts (removable clips)?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-01-2012, 10:57 AM
darnellsgarage
Yes. They were, they all took the studs with them when I removed them.
don
Old 01-01-2012, 11:18 AM
9FF 9FF is offline
9FF's Avatar
I would drill them all out and fit rivet-nuts, then bolts to secure. Those studs that broke off are all welded in place and it would be a pain to strip carpet, soundproofing, paint & under seal to weld new ones in.
Old 01-01-2012, 01:22 PM
porschetub's Avatar
Top marks on the rivet nuts,best fix really,wouldn't the studs be in the sill area though?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 01-04-2012, 01:04 AM
9FF 9FF is offline
9FF's Avatar
Quote de 9FF
Depends which ones broke, some are in the sill, some in the floorpan. I replaced a broken stud in my floorpan with a rivet-nut and short stubby nut, however if one of the sill studs broke you will have to get more creative. Maybe a small countersunk bolt from the outside of the sill so that it lays flat in the exterior of the panel and allows a nut to be screwed on the inside. Either way if you weld in a new stud or fit a countersunk nut you will have to refinish the outside of the sill, the nut will cut down on the refinishing required.
Old 01-04-2012, 04:06 AM
