944 rear rotor dimensions
Hello,
I need some measurements from 944 rear rotors, 86 and older, preferrably from turbo rotor. In my pic needed dimensions are: 66, 71 and 180mm. What these are in reality? I plan to make aluminum hubs for wilwood rotors to use them at rear, i have narrow aluminum arms at the back on my beetle. ![]()
Garage Helper
Dimensions change between '86 NA and '86 Turbo rotors at outer diameter.
'86 NA = 289mm '86 Turbo = 299mm Dimensions change between '86 NA and '86 Turbo at outer disk thickness. '86 NA = 20mm '86 Turbo = 24mm
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Yes i know that
But i am after these dimensions at my pic: 66, 71 and 180mm.I need to correct the design on my rear hubs for 12.19x0.81 wilwood rotors
Garage Helper
Well sorry about that - The only other dimension I can verify is the inner diameter of the rear parking brake drum at 180mm, and it is the same dimension on both the Turbo and NA.
Ok,
Now i have rear arm dimensions, so parking brake drum dimensions is good for me now, thanks ![]() |
