Strange vibration
I have a strange vibration on my 87 that shows up under accelleration. It feels like the rear wheels are badly out of balance and it makes the shifter jump a bit.
Different wheels and tires on all 4 corners made no difference.
Any idea what to look at?
Old 01-11-2012, 03:00 PM
Repack CV joints. It may or may not be the problem, but it couldn't hurt.
1988 944 turbo
Old 01-11-2012, 06:44 PM
Toofah King Bad
Rasta Monsta's Avatar
Motor mounts?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-11-2012, 07:41 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Porsche Crest Vibration started laste night, Left side rear.
Drscope;
Strange, last night mine started to have some the vibrations as if wheel nuts were loose. Driving locally. Check the rear left wheel with torque wrench, all is tight. Probably the same thing. See if i can get to them this weekend.
Car sat for 2 yrs for repairs and upgrades.
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 01-11-2012, 08:47 PM
I've had a few different sets of wheels and tires on the car and the vibration is still there.
I've had several 944's over the years and none of them ever felt like this.
I doubt it's CV joints. It doesn't make the usual knocking noise when turning that you would get from a dry CV.
Maybe it's motor mounts, but again I've had bad mounts in the past without this vibration. Anyone have any good suggestions on ways to check them other then the obvious are they broken?
It just really feels like a badly out of balance wheel or out of round tire on the rear.
I was hoping someone could suggest something I haven't thought of yet.
Old 01-17-2012, 06:24 PM
GreenWater's Avatar
Wheel weights came off the wheel and they are actually out of balance?
I would guess it isn't the motor mounts, mine are wore out and my car doesn't shack under power, only at idle.
Is there any sealant in the tires? Like slime?
Unless the fluxcapacitor is broken. That can cause all kinds of trouble.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 01-17-2012, 08:53 PM
Muffler bearing.
Old 01-17-2012, 11:54 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Do you have the rubber center clutch? I'm also wondering if you've had a rear shock self destruct.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-19-2012, 07:53 PM
GreenWater's Avatar
I am thinking you have a serious squeaky hatch problem. ha ha Just kidding.
Could there be a problem with the transmission? This maybe a stretch, but how about a gear that is severely worn. I am thinking of the ring and pinion gears. If they are worn bady and under normal power they are not slipping but under enough power the gears are not properly seating into each other and are kind of jumping around making the shaking in the car and also causing the shaking in the shifter. Just me imagining out loud.
84 944
Old 01-19-2012, 09:03 PM
968 GUY's Avatar
Transmission mount? Loose CV joint bolts? Clutch slipping?
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 01-20-2012, 08:55 AM
Did you even inspect the CV joints? Grab hold of the half shafts and give 'em a good shake.
1988 944 turbo
Old 01-20-2012, 09:26 AM
CV joints seem to be in good shape. I have not taken them off, but there isn't any sort of unacceptable play in them.
Transmission mounts appear to be OK, no movement when things are pryed on.
I suspect the car has the rubber center clutch, but don't know for sure. Past experiance with them is you can feel slop in the drive train when they start to go. This car when in gear and parked doesn't seem to have any excessive play like that.
I have had several 944's and never experianced anything like this before with any of them.
It's been the same even though we have had a few different sets of wheels, tires on it. So it's NOT a wheel balance issue or slime in the tires.
We've had the car for about 2 years now and it was like this when we got it. It has NOT gotten any worse, but it is an annoyance simply because I can't find the source!
When we bought it I figured it was simply wheel balance. So the old tires on phone dials came off and another set of tires on Fuchs went on. Still the same. Those tires were of unknown age, and the Fuchs really weren't the right size, so in short time another set of Fuchs were obtained, new tires were installed, everything was computer spin balanced and the vibration remains.
I have also installed another set of wheels and tires from a 911 and it is still there.
So with all those different sets of wheels and tires I'm fairly confident I can rule out wheel/tire balance.
Rear wheel bearings are good. No play.
Rear shocks are maybe a little squishy for a track car, but are still doing their job for a street car.
I just don't know where else to look.
I'm starting to suspect a torque tube issue.
Old 01-22-2012, 11:21 AM
Toofah King Bad
CVs can't be effectively inspected without disassembly, IMO.
On the other hand, could your R&P be on the way out as suggested? Drain & check gear oil for chunky bits?
Old 01-22-2012, 01:06 PM
In the Fires of Hell.....
kdjones2000's Avatar
For a track car, I am guessing that it's the rear transmission mount. Stock they are floppy and when you get on the power the rear drivetrain starts moving all over the place, making the shift handle move.
Modify yours, or try a semisolid or full solid mount and see if that's the problem.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 01-22-2012, 02:06 PM
