S2 Valve Cover
Beginner Question......Ive got a small accumulation of oil laying on the valve cover, and its coming from this black round cover. What is it? Is there a gasket under there?
the green scribble is where the oil lays (i wiped it clean earlier today)
^^Gave you the answer on RL with parts #, available here at Pelican.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
AutoX
Located on that plastic cap/plug is an o ring that needs to be replaced. When you purchase a cam cover gasket kit it comes with the kit. There is a snap ring on the back side holding it in place.
Just did the tensioner pads, bummer. Can you get the cover off with the fuel lines still attached, or do they need to be removed?
^^ Ernie I have taken my valve cover off without removing my fuel lines.....
