Eureka912
bavarianrescue's Avatar
BMW Roundel What is This White Plastic That's Leaking Coolant?
I have an '84 944 and this plastic piece is leaking coolant. The bolts are tight and it's not cracked as far as I can see, but is still possible. It's the part next to where the large end of the hose connects. What is it called and where do I get one?
David in Eureka, CA
1966 Porsche 912-1966 Studebaker Commander V8
1981 Mercedes 380SL-1984 Porsche 944
1986 Jaguar XJ-S V12-1986 Corvette C4 Z51
2007 Audi A4 Quattro Cabriolet(wife's ride)
2010 BMW 328i/M Sport(my daily)
Old 05-09-2012, 05:22 PM
ernie9944's Avatar
This is a block off plate for an updated turbo water pump,there is an O ring in there part# 999-707-283-40-M213 -$1.75. You migth just need a new O ring but if crack & need to be replace part # is 944-106-313-00-M260 -$4.75 both parts are available from our host Pelican (New Parts Catalog) Pelican Parts - Porsche Parts & BMW Parts - Automotive Parts and Accessories - Porsche & BMW
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 05-09-2012, 05:36 PM
Custom User Title
mikepellegrini's Avatar
That's the take-off for the turbo waterline.
There should be a blockoff stopper inside. Rather than buy a new one, if mine were leaking, I'd take it off and reseal it with silicon goop.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 05-09-2012, 05:37 PM
Proprietoristicly Refined
John_AZ's Avatar
OR---maybe you need a new waterpump if the front WP pully seal is leaking.......................
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-09-2012, 05:41 PM
ernie9944's Avatar
Lol why take a chance & use silicon goop on a very important part of the cooling system which only cost $6.50 & not replace with a new one.This is beyond my comprehension.
Old 05-09-2012, 05:51 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Hard to see in the picture with the bright light on it but It almost looks like the coolant is coming from the hose connection. But, if you're sure it's the plastic piece, the cheap O ring will fix it. If it was me, I'd get a new plastic piece that usually includes the O ring (but not always). They aren't expensive and I'm just a bit anal about stuff like that.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-09-2012, 06:18 PM
Eureka912
Thank You All
This is exactly what I wanted to know. I know this is the part that is leaking as I ran the motor and watched it drip. I'm also a long standing member of the Anal Brigade, so both parts will be replaced. Thanks again and HappyMotoring!
dws
Old 05-09-2012, 06:43 PM
9FF 9FF is offline
9FF's Avatar
WATER PUMP FITTING 924S / 944 thru '88 / 944S (#4) at LINDSEY RACING - Your Porsche Performance Parts Center
Or if you are really anal and want a custom fitted replacement instead of using a modified turbo take-off try this: LR TURBO THERMOSTAT BLOCK OFF (#4) at LINDSEY RACING - Your Porsche Performance Parts Center
Old 05-09-2012, 07:37 PM
Custom User Title
Because if you ordered your $6.50 part right now off Pelican, it probably wouldn't get here till next Monday. I'd rather stop the leak now than wait till next Monday. D'oh!
16 Ford Expedition
Old 05-09-2012, 08:44 PM
