Shifting
My 1986, 944 has vey vauge shifting paterns, does it need new bushings in the shifter or tranny?
Old 05-18-2012, 12:10 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Sounds like the bushings and bottom ball pivot (nylon) on the shifter itself. The Tranny mechanisms are out in the elements and even though mine were weathered, when I put the tranny back in (my shifter bushings and ball were tight) I still had a positive shifter.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-18-2012, 12:29 PM
ernie9944's Avatar
__+1 on the bushing & lever
Peter__ First welcome to Pelican, I usually recommend buying parts from our host Pelican but since your in Canada maybe you should try this place ,very reliable & good shipping service plus no custom hassle enter car description & scroll down to "transmisssion & transaxle manual" your looking for part #OES 1640738 which is the bushing & OEA 1618551 the shifter lever.GL solving your problem.---- autopartway.com
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 05-18-2012, 01:19 PM
shifting
WOW, thank you both so much!!! Appreciated
Old 05-18-2012, 04:47 PM
ernie9944's Avatar
For all your car maintenance (including changing the bushing/shifter arm) this will be the garage you'll spend time in from now on Clark's Garage Home Page once on site enter "Garage Shop Manual" for your shifter enter letter T scroll down to (checking repairing &replacing shifter lever & shift linkage,pics are include in the DIY.
Old 05-18-2012, 05:40 PM
968 GUY's Avatar
Also make sure the set screw is tight on the trans. end of the shift mechanism.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 05-18-2012, 07:48 PM
Back from Beyond
Cheap and easy fix: make sure the 2 bolts holding the shifter mount on the torque tube are tight. This plate holds the ball cup and if those bolts aren't tight your ball wont stay put...heh...
Just pull back the shift boot and the insulation and have a quick look.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 05-18-2012, 09:06 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Most of the time it is the lower nylon cup bushing at the base of the shift lever, and along with that there is a stud of types that juts off of the shift lever, and to that is attached the shift rod coming from the back. One can notice when this stud/attachment arm is worn and rounded and causes sloppiness in the shifting. Also check the inside of the cylinder attachment at the end of the shift rod. If this part is all wallowed out on the inside where it attaches over the stud of the shifter lever the slop in the shifting will be greater.
One can replace the lower ball cup bushing and the shift lever fairly easily. The shift rod that is attached to the shift lever is a little harder to replace.
See also: Porsche 944 Shifter with bearings to fix the extra play while shifting A fellow Pelican member has designed this modification system to rebuild the shifter problems.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-19-2012, 09:00 AM
Thanks to all for the advice, I ended up getting a new shifter from 944 ONLY and could not be happier, easy to install and it works like it should!
Old 06-02-2012, 08:10 AM
