oil pressure
my 944 85/5 has no engine noises etc but after highway driving and stopping at intersections the oil light flickers at around .5bar i have changed the pressure switch and also the oil pressure relief valve to the new design i'm running 15w50 redline synthetic. when cold she runs at 5bar solid and then when warmed a little idles around 3bar to 4bar but the presure flicks up and down in .5 bar increments.
Has anybody any ideas please..
It is normal for the oil pressure to drop quite a bit warm and idling (especially with the clutch in) but I can't say I've seen it as low as .5bar. Maybe a little under 2 is the lowest I've seen it.
When it is at .5bar is the little red light on? Others should chime in to give insight to a safe warm idle pressure. Be safe, have a good evening! Cheers |
944 addict
What part of the country do you live in? How many miles on the engine? Is the temperature outside 40degrees f or below when this is going on?j
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Toofah King Bad
Mileage on the motor is a good question. I have run a 2.5 in a 24 hour enduro, and the idle pressure never went below 2 BAR in the pits. Cracked pickup tube?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
That "flickering" of the pressure gauge makes me worry about rod bearings... is said to be typical (and has been in my one case, on a 924S)...
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
oil pressure switch
I had that problem with my '88T last summer, I went threw two of the off brands oil pressure switches before I realized( with the help of this forum) I had to get the OEM switch. If you don't have the OEM, about $150., than your not going to get an actuate reading.
So is the pressure at warm idle 4bar or .5?
The way I read it was that after changing th OPRV & sender, it is 3 to 4 bar warm. That is pretty good.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
Just went through this with my 968. Anyone want to buy an aftermarket oil pressure sending unit? Porsche OE is the only way to go on this. I picked mine up for just under $100 from Sunset Porsche. |
Thank's for the replies. The car's only driven between may to september with 140k kms
the light flickers on and of for a few seconds after comming to a stop and engine hot. 1000rpm and above pressure stays 3 to 4 bar when car driven locally not highway light doesn't flicker on. the weired thing about this is change of brand oil seems to change the frequency of the symptom I always used mobile 1 20w50 had no symptom. now not available here in toronto had to use 15w50 now signs of symptom castrol 15w50 syntech always there now trying redline from last season 15w50 occasional sign but flickering needle .5 bar iether way persists.on idle it will read say 3bar then jump .5bar and back etc?? |
I think you hit on your problem. You changed the Oil Weight from 20W50 to 15W50 and the Brand. Go back to using a 20W50 and see if that cures your oil pressure problem.
Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
Redline 20w50 porsche o/e filter the old girl under extreme running the stopping has since had no light flickering on. pressure no lower than 2 Bar at idle. but the guage still jumps .5 bar when idling and pressure reading around 3 bar hmm me thinks gotta lektric problem lol.
Check the wires. My oil pressure gauge flickers all over the place right now and it's being cause by bad wires. I have just been to lazy to fix them, but I know the oil pressure is fine.
www.Only944.com Porsche parts, Only better, Only944 87 944 N/A 165,000 miles 84 944 Saved by God, because I could not. |
will do thank's i know they run down the belt covers and the belts have been changed.
Your car & motor is now twenty- seven years old the motor probably has never been redone in all those years,why don't you try some good old dino oil (Valvoline Racing VR1 20w-50.You migth pick up 1 to 11/2 bars of oil pressure with it.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Proprietoristicly Refined
Step one: Rennlist Discussion Forums - View Single Post - Why Does The Oil Pressure Gauge Bounce? Step two: Rennlist Discussion Forums - View Single Post - Why Does The Oil Pressure Gauge Bounce? Read entire thread: Why Does The Oil Pressure Gauge Bounce? - Rennlist Discussion Forums Update: Still steady--no low rpm bouncing and hot engine freeway pressure 4+psi steady John.
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
would you believe it''' a faulty oil pressure switch from porsche. I removed the switch and hooked up a pressure test kit. after high speed, and yes pleading the fifth on the number lol i pulled off the highway very hot engine was 2 bar and no flickering on the guage.
told the local porsche dealer gave him back the old switch he gave me another and the old girl is happy.. pressure accurate and no frkn flkring.lol Thanks again everybody for the input. |
that was the cause of the needle jump .5 bar too
944 addict
porsche parts losing their reliability? They didn't find a supplier in Pakistan did they?
