Does the 944 accept double din radios?
Since i have not seen my 944 in a few days.....at my father's house.....i dont know if it does. Im not sure of the depth. I want to upgrade the 2-knob cassette radio to a new radio with usb, sd and bluetooth and a nice large screen for easy viewing.
soo....does the 944 (85.5) accept double din radio?
Old 07-19-2012, 09:03 AM
Catamax944's Avatar
yes New Stereo Head Unit - Double Din. - Rennlist Discussion Forums
Catalin
'86 DD
Old 07-19-2012, 09:29 AM
Originally Posted by Catamax944 View Post
Thanks for the info
Old 07-19-2012, 09:39 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
A double din head unit will fit as long as it is shallow depth. I have forgotten what the standard depth is for now, but the bottom of the unit may bottom out on center torque shaft tunnel (because of the head unit's installed angle) if the head unit is to deep. If that is the case then you may have to shop around and find an adapter install plate for your new depth (Those extension plates come in 1/4", 1/2", 3/4" and up to 1" depths/extensions), to extend out the face of the unit on install.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 07-19-2012, 09:47 AM
thanks...good to know. I will remove the radio and take measurements of the lower din depth and compare them to the radios im interested in
Old 07-19-2012, 10:57 AM
Question just for my own edification, will the "guide" track for the single DIN radio have to be modified or cut out to allow the double DIN chasis to slide past? Just curious. Thanks, JAX
86 951 blk
Old 07-20-2012, 04:50 AM
IIRC, The double din is twice the size and will require slight modification cut out of the area down into the cubby area under the standard radio. I hope I'm wrong.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 07-20-2012, 05:07 PM
