'85 1/2 With a Backfire
Ok, calling all 944 Guru's- I just picked up a beautiful, garage kept, 1985 1/2. Everything on this car works! However, when I turn it off, more times than not, I get a backfire. The car sat for 8 years under a cover in a garage, but it started right up with a new battery. Everything seems to be connected. Any ideas? Thank you for your help!
Custom User Title
Sounds like a great find! Congrats.
However, if it sat for 8 years, before you do anything at all, please change the cam and balance belts - ASAP. You've got an interference engine there, and if the cam belt breaks, you're gonna have some very unhappy valves and/or pistons. The maintenance interval is usually 3-4 years or 45,000 miles. 8 years is about double the life expectancy, so you're living on borrowed time. I wouldn't even start it once more before changing the belts! Camshaft / Balance Shaft Belt Information Timing Belt and Balance Shaft Belt Installation Timing Belt and Balance Shaft Belt Tensioning As far as the backfire is concerned, it could be a whole lot of different things. But first, the belts!
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
The Kevlar timing belt is on order. Until it gets here, I'm hoping to get the backfire fixed.
Thanks! |
My 944 , acquired Xmas 2011 was running on a belt set from 1999
![]() The balance belt was broken and jammed ; the timing belt was severely cracked - the PO had dodged a bullet for sure and I held my breath of the drive home... I've still got the original clutch , which one day will go bang . Rubber sucks!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Proprietoristicly Refined
Your really caught the fever! http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/689787-87-944-n-surging-issues.html Short reply this time. Could be a leaky fuel injector or a degree off time. GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
