PorscheChef's Avatar
'87 944 N/A Surging Issues
I have an '87 N/A which was pretty much rebuilt. Now as I am driving, it surges a little bit and seems to be a little under powered. I checked all of the vacuum lines and they are correct. Any other ideas?
Old 07-19-2012, 07:07 PM
Check the timming My924 would do the same thing and it hated intown driving till i played with the timing.
Old 07-19-2012, 10:01 PM
Proprietoristicly Refined
John_AZ's Avatar
Get some engine information with a compression and leak down test
Compression-leakdown test
Remove the DME relay when you do a compression test!
This will tell you the condition of the engine.
Clean electrical connections and grounds-Porsche WSM first step.
The surging is usually a vacuum leak.
Even though you checked the vacuum lines, the leak will most likely be in the hoses to the ICV and intake hose connections under the intake manifold or the J-Boot air intake.
There are a lot of WYAIT-While You Are In There- items to do when you take the intake off.
Start with removing the J-Boot air intake.
Check all the hoses for cracks and get new non perforated hose clamps or the OEM clamps- Oetiker Stepless Ear clamps.
The throttle body should be rebuilt.
Throttle Body Reseal kits for Porsche
Check the AFM thoroughly:
Air Flow Meter (AFM) Operation and Testing
If these repairs do not solve the "little" surging/ "little power issue do the complete under intake maintenance.
Get the injectors cleaned, resealed and matched-- WitchHunter Performance - Injector Cleaning & Flow Testing Services
Clean the ICV
Replace the AOS seals
Replace hoses to the ICV and clamps
Get the oil dipstick "O" ring $3
Then check the AFM for proper working condition.
Were you expecting a magic chant?
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-20-2012, 05:06 AM
WOW! Great information! Thank you for your time!
Old 07-20-2012, 09:05 AM
AFM #725
Gawernator's Avatar
John is "the man"
Old 07-20-2012, 11:46 AM
Cleaning the Air Flow Meter did the trick. Thanks again!
Old 07-20-2012, 06:51 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
You got out cheap. Good on ya.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-21-2012, 05:25 PM
