I did not get the socket extender pieces. Did I make a mistake in ordering?
Re: Rogue Tuning NA-Tune: MAF conversion for the 944NA!
I am working on getting a detailed step-by-step install directions done....
If you don't have an easy spot for switched +12volts, then you can use the coil. BUT make sure you connect to the correct side (the black wire). |
Here is my SNAFU. I removed the socket and soldered the small board in its place. I looked again on the site where I placed my order, there is no place to say what socket you have, I assumed everything needed was included either way.
http://forums.pelicanparts.com/uploa...1363366448.jpg I have a few solder joints that are bridged here, can't remember if they were that way before I removed the socket. http://forums.pelicanparts.com/uploa...1363366522.jpg |
I'm almost done, but I can't find 12 volts at the diagnostic port. Do I have to disassemble that entire area to find a wire? That looks like a PITA to disassemble... I was also told I can also get 12 volts from the horns, but I can't seem to find them :mad:
Whereabouts in here can I find 12 volts? http://i135.photobucket.com/albums/q...ps7a53922b.jpg |
I do specify that a 28pin DME is required for any of my Tunes. Just the same a late (85.5+) DME is required. I can only state the requirements of the kit... If something is not clear feel free to give me a call or email. Quote:
I have finished my pictorial. I hope it helps some people. If I forgot any steps or you'd like better pictures just let me know and I'll go back and do those steps/take a better picture. Alright, fist things first. Take a few shots of tequila or your alcohol of choice http://i135.photobucket.com/albums/q...ps5ebebf90.jpg Once you're done that, disconnect the battery. I have a knob to disconnect mine. If you don't have one of those, then you'll have to loosen the nut and pull the lead off http://i135.photobucket.com/albums/q...ps5337b41c.jpg Next we're going to remove the DME. Pull back the passenger side carped (it's velcroed on there) and you should see something like this http://i135.photobucket.com/albums/q...psd804b628.jpg Unbolt the kick panel, disconnect the DME, and you should see something like this http://i135.photobucket.com/albums/q...ps4bdfa7f4.jpg Unbolt the DME and flip it over. Pry up on these tabs with a flat blade screw driver http://i135.photobucket.com/albums/q...ps5e341665.jpg Remove the metal cover and GENTLY push up on the top board at these two posts. Do not push up at the very edges of the board. http://i135.photobucket.com/albums/q...psc02c7b4e.jpg Once you have the DME apart, carefully stick a flat blade screwdriver under the chip. Wiggle it around a little, then switch to the other side of the chip. Do not just pry up on one side of the chip. You will bend the pins. Once it's loose, gently lift it out and set it aside. I'd recommend putting it in the static free box your new chip comes in. http://i135.photobucket.com/albums/q...psc5905d37.jpg After your chip is out, insert the new one as shown: http://i135.photobucket.com/albums/q...ps8f07c4f1.jpg After you're done that, reconnect the DME and reinstall the kick panel (sorry, no pics) |
The next step is to remove the top of the airbox. Remove the screws holding the lid on and the clamp that holds the belt vent tube to the airbox
http://i135.photobucket.com/albums/q...ps80d28b29.jpg Once you've removed the top cover, loosen this screw and remove the clamp attaching the J-boot to the AFM. There is no J-boot in this picture because mine seems to have gone on vacation :mad: http://i135.photobucket.com/albums/q...ps54ca1dac.jpg Disconnect the connector for the AFM and remove the four screws holding in the AFM. The one on the bottom left is a real pain in the ass to remove/install. If you take your time you'll get it out http://i135.photobucket.com/albums/q...ps646bd35b.jpg Look at that difference in air restriction! http://i135.photobucket.com/albums/q...psc45109d8.jpg Throw your AFM in the garbage http://i135.photobucket.com/albums/q...psc8b84a75.jpg Just kidding Hold the MAF housing in place and start all four bolts. I'd recommend screwing them in about half way http://i135.photobucket.com/albums/q...pscbf5ba4a.jpg The one on the bottom left takes some ingenuity to get tightened down http://i135.photobucket.com/albums/q...ps45b391cd.jpg Now it's time to go inside and do some soldering! Get out your soldering iron, some solder, a ring connector thing, some heat shrink, and a heat gun http://i135.photobucket.com/albums/q...psb0b7a88f.jpg |
Slide on your heat shrink, stick the the wire in the end of the connector, and squeeze the end of the connector together with some pliers.
http://i135.photobucket.com/albums/q...ps0724baba.jpg Make sure your soldering iron is 100% heated up and place it on the wire. Touch the piece of solder on there until it covers the entire end of the wire and flows down inside the part of the connector you squished. Watch out, the connector gets very hot and can burn you! I needed something to hold the connector down while I soldered it, so I used a can of brake fluid from my VW. http://i135.photobucket.com/albums/q...ps9f9bc31e.jpg Slide the heat shrink over the connector and use your heat gun to shrink it. Make sure it is 100% shrunk so no dirt, water, etc can get in there. http://i135.photobucket.com/albums/q...ps4db71d06.jpg http://i135.photobucket.com/albums/q...ps6c495e22.jpg Go back to your car and pry apart the cover for the coil with a flat blade screw driver. This thing is a ***** to remove with the headlight motor in place, so I usually unbolt it and turn the motor forward. http://i135.photobucket.com/albums/q...ps6c4c7343.jpg Once the cover is off, you should see this. Here are the black and green wires Josh is talking about. DO NOT USE THE GREEN WIRE!!!!!!!!!!!!!!!!! http://i135.photobucket.com/albums/q...psafdb7b76.jpg Loosen this nut on the coil. It is 10mm http://i135.photobucket.com/albums/q...ps822883db.jpg Tighten the nut down http://i135.photobucket.com/albums/q...psebb43727.jpg Go to the MAF housing and connect the harness to the MAF sensor and the AFM connector http://i135.photobucket.com/albums/q...ps6ed575f8.jpg http://i135.photobucket.com/albums/q...ps5a667a55.jpg Reconnect the J-boot (make sure none of the vacuum lines attached to the bottom came loose), put the airbox together (make sure you have everything out of there first!), put the cover on the coil, reconnect the battery and start 'er up! |
Chunkerz - very helpful, whatever you're running for you got my vote! Thanks man!
Glad you guys like it! I need to retake a few of those pictures. Stupid 5 megapixel camera making my pictures all crappy....
Wow very nicely done. I laughed out loud when I saw you throw the AFM away
please say you didn't throw the AFM away!!!
He said JK
u shoulda went office space on AFM hehe.
AND HE THREW IT ON THE GROUND! |
Wait. I'm NOT supposed to throw it on the ground :confused: That might explain why it stopped working :(
Why is the 944 forum plagued with Office Space references :confused:
| All times are GMT -8. The time now is 09:28 PM. |
