Location: In a dumpster behind Albertson's in Los Angeles County
The Global Warming Potential of HFO-1234yf is 4 compared to 1400 for R134a. Manufacturing of the R134a will eventually cease just like R-12, and once that happens, only what is recovered from systems will be available....just like R-12.
We can thank the European Parliment for the change, they decided that no cars maufactured in Europe after Jan 1, 2011 would use R134a, and the SAE Interior Climate Control Committee decided to follow suit (most likely with some pressure from the EU) so that European car manufacturer's would not have to run 2 different systems (HFO for Europe and R134 for US). Also, R134a is a "blend" while HFO is a single component refrigerant. Welcome to the "greening" of the auto industry.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Just thinking out loud
In other words, Dupont and Honeywell have a hell of lobby team. It's going to be another drop in refrigerant, just like R134a was. CFC's and HFC's are still being manufactured and will most likely continue to be manufactured for quite some time...
83 944 91 FJ80 84 Ram Charger (now gone) |
AFM #725
It's all about profit lol
86 951 blk |
Blame it on SAE Interior Climate Control Committee, which is made up of: Representatives of the US automobile manufacturers, component and equipment manufacturers, the EPA and other MVAC experts.
Unfortunately it will NOT be a drop in like R134a, operates at a much higher pressure, high enough that it requires additional sensors, and it is also mildly flammable, so leak sensors are also required.
AFM #725
Also, I'm sure they will move to make it illegal to produce R-134a so that they can really profit off the new stuff.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Get your 134 while you can, folks. |
I also belong to a Me/Be a Dodge, and a BMW forum, and I can certainly say the info flow here tops them all.
86 951 blk |
AFM #725
Woohoo! I concur.
blimp
AFM #725
Might be in the budget after all..... :'(
Patrick
Very interesting... After I bought the 84 NA back in May, I discussed converting to 134A with my mechanic friend and he told me that all the old oil must be evacuated in order for the system to work properly. He set up the system to accept 134A, I drove around with the AC on for a couple of days then evacuated the system a second time and installed a new drier. My AC has been working great since (June) to the point where I didn't need to turn the fan on high! The best part was the job cost me $60.00, including the PP drier ( I think it was @ $11.00 or so).
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
good, but why the sad face?
AFM #725
Lost a fiancé and a pregnancy in one fell swoop...
Anyways... How does this hose modification work? And what's the real-life difference one will notice with this condenser? Pretty easy install for a relative noob like me? |
Holy crap...very sorry to hear that, man. Things don't always go as planned, but how you deal with them and move forward is what proves who you are. Life goes on.
Hose modification - hoses get made longer, using different fittings than stock on the condenser end. The stock compressor-end and receiver-dryer-end fittings are re-used though. If you had the condenser and the hoses ready to go, it shouldn't take more than a few minutes to re-install everything. Real life difference is subjective, depends on what condition your current condenser is in. Just going to a new, clean condenser versus the old one will improve how well the AC cools the car. The design of this unit compared to the stock one will compound that improvement, making the overall AC process slightly more efficient, meaning cooler air for you in the cabin, less work on the AC system and less work for the engine to drive. Last edited by v2rocket_aka944; 11-11-2012 at 05:30 PM.. |
Redline Racer
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
AFM #725
Took a look at my condenser today... about 5 million rocks and some seriously smashed up fins etc... Put me down for one.. probably will order in December or January.. and will need the hoses/fittings. Gonna have to refill the A/C system again huh? Just re-filled a few months ago
Probably time for a new drier as well.
bump
Some (poor) pictures showing the condenser installed on a 944S...
AFM #725
You don't need to remove the nose panel for the install do you?
