Installed Clear Corners..now Blinkers dont work?!?!?!?!?
I received my clear corners today... I put them in..put the orange bulbs into the stock harness...then i put in the clears...and now my blinkers dont work?!?!?!
When the lights are off the front right works...when the lights are on none work they just stay on like parking lights...and the rear left one stays on solid! Did I burn out some fuses or something? I am really confused
1993 Porsche 968 85.5 Porsche 944 |
Check the clear and yellow bulbs side by side and see if the silver connector bumps on the bottom match up the same wrt the little lock posts on the sides. If the connectors on the bulbs don't line up with the connectors on the sockets you will get the wrong lights or none at all. OBTW where did you get the clear corners.
Louie
Louie '85 (Early) 944 - Beater '87 924S - Crunch/Rebuild '76 924 - Long Gone "If everything seems under control, you're just not going fast enough." - Mario Andretti |
the bulbs have to be insterted the right way as well. i replaced a turn signal bulb in mine and it wasn't blinking. i switched it around and it worked just fine. both bulbs front and back have to be on the same polarity.
Clear corners, huh... For which car? (968 or 944) And where DID you get'em?????!!!
1989 944 Grey/Linen lthr |
Must be for the 968, I've seen them before.
