new tie rods/front alignment help
just put new inner and outer tie rods on after conversion to manual steering on 88 NA. how do i get the front end straight enough to keep from tearing up tires on the way to alignment shop. All input greatly appreciated
Old 01-25-2013, 04:35 PM
This link will work.
DIY: DIY front toe settings
Clifton
Old 01-25-2013, 05:58 PM
Proprietoristicly Refined
John_AZ's Avatar
Top Banner==="Tech Info Center"
I have used this process many times-PS rack swap, MMs, tie rod ends, front strut replacement ....
Pelican Technical Article: Home Alignment
J-AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 01-26-2013, 06:34 AM
Thank you much, I should be good
Old 01-29-2013, 05:27 AM
if you don't have a toe plates, just use a long enough 2x4 or angle iron. place it against the edge of the tire at center of wheel height. have a second person do the same on the other side. tape measure front of tire vs rear of tire.
u can get within 1/8" reasonably with just that. that's enough to drive a bit to the alignment shop.
also depending on what wheels/tires you have, you may be able to eyeball toe. facing the back of the car, look at the front tire along the outside edge. move left/right until you can just BARELY see the front edge and the rear edge of the front tire. at that position, you should see the edge of the rear tire. if u don't see rear tire at all, you're way toed-in. if you see the middle of tread of the rear tire, you're toed out. of course this doesn't work if you're running substantionally different offset wheels or if you're running really big tires in the rear
Old 01-29-2013, 09:22 AM
