advice needed: coolant leak
'87 944 na
pic attached I noticed a drop of coolant (nice and clean looking) on the hose that goes from the water pump to the side rail (?). If the hose itself is OK, should replacement of the hose clamp fix this? more to the point - if I remove that hose clamp, is it going to spray coolant out/require a bleed? ![]() p.s: will coolant ruin rubber e.g. the steering boots - or is it just the same rubber as for the various coolant hoses? |
AFM #725
Lol, I'm fixing my coolant leak tomorrow! Do you have records of the heater hoses/coolant hoses being changed? You might as well replace them all, maybe the HCV too at the same time. The hoses are inexpensive. That hose clamp looks hella rusted... you should maybe get new clamps too, also super cheap. I'm gonna guess that old rubber hose is bad. I also have no idea what that rail thing is called either.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Mein Gott!
Replace the entire hose along with that rusty clamp. I've seen no less than three of that same part get destroyed over the years on my car. It is due to the location where it gets blasted with heat all the time. If you can't wait, just get an equal length of heater hose at your local auto store. Relatively easy fix.
Johnny 1987 944S 1984 944 (R.I.P.) 1972 Triumph TR6 - 100% trouble free between breakdowns 2003 BMW 325xi |
What do I measure on the hose clamp to get the right match in the catalog?
AFM #725
Dude go to a local auto parts store and buy them
for our information, just looked in the PET. the first diagram* has:
the rail thing: 12 : 944 106 243 03 water tube the hose clamps: 22 : 999 512 392 00 hose clamp 23-35 three needed 23 : 999 512 346 00 hose clamp 16-25 one needed the hose: 11: 944 106 241 03 water hose [*] "944 2 USA 88 Katalog 1985-1988", model 9442 year 1988 MG 1 SG 05 illustration 105-05 UPD 248 19:24 31.01.2010 ... BTW, been meaning to ask this... how the H is the PET supposed to be read, anyways? is there a tutorial or something? there are two more diagrams that look similar following this one and all the numbers/codes appear the same, so what do we look at to know what we need - without going fine-grain on the differences? |
Mein Gott!
You're in luck. I found a spare water hose in the garage this morning. Here it is if you want to get a similar measurement heater hose. But if you're willing to wait, PM me your mailing address and I'll just send it to you on Monday:
There are several different models of engines that are in 944's.To the right you will see in the header,"model",find the model of your engine and choose the correct partwhen looking them up.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
so I guess M44 means "model 944", but then the "05/06/07", "08/09", "10" means ... what exactly?... I asked on another thread where to find the stamp on the engine, gonna do that as soon as I get a chance... just a note here: the next diagram (p.50, ill. 105-07) M44.40 the last diagram (p.52, ill. 105-10) M44.50/51 M44.52 |
BTW who is that German officer avatar you have? |
Mein Gott!
No problem. The correct part number is stamped on it but the cell phone pic is so bad it didn't even come close to showing up.
Haha the avatar is Gobler from Raiders of the Lost Ark. My favorite film. Ever.
AFM #725
